HELP!!! something is not right!!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by juliolopezgonzalez, Feb 4, 2012.
  1. juliolopezgonzalez
    juliolopezgonzalez Junior Member
    30
    SoCal
    So I am driving back from a gorgeous bike ride this morning and going down a hill the dreaded red triangle goes off. Car has 120k, all maintenance at the dealer. Scangauge does not read any codes. I made it home and parked. During the 3-4 miles that I drove with the triangle on the car behaved normal. Powered it off. Powered it on again. Same problem. See attached pictures, as you can see main battery looks very healthy and there is less than a month on the optima yellotop 12v.
    Any input would be greatly appreciated, since I have a 1,000 miles to drive on Tuesday, and not sure this car can handle that right now...
  2. cnschult
    cnschult Active Member
    772
    97
    Michigan
    i've only gone into maintenance mode to check battery voltage levels, but i could have sworn I've read a post here awhile back that somewhere in maintenance mode the car will tell you the codes its procuring. I think it was a post regarding a code that was only meant for Europe and wasn't supposed to show up here in America, something like that.
    if you've replaced your battery with an optima, I'm assuming you've done it yourself, are quite handy, and you know how to go into maintenance mode, and can snoop around there to see if any codes are popping up there, let us know what you find. I think that VSC warning light is a huge clue and there have been many posts regarding your problem, so I'm sure its just a matter of time before someone lets you know whats wrong with your car and hopefully the problem is a cheap and easy fix.
  3. Flying White Dutchman
    4,376
    313
    i never see any codes based on the 12 volt battery problems beside ABS etc because of low voltages
    check your wires of your optima to see if they are attached and not lose
    you never now!
  4. juliolopezgonzalez
    30
    SoCal
    Thanks guys for the insights, I actually ordered the Optima online and took it to the Toyota dealer in Oregon to have it installed. 1,500 miles on in as of today. Will check the wires before going down to the dealer here in San Diego. I just dont want to ask one dealer to solve a problem that another dealer created, rather see if I can make it back to OR...
  5. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Did you check the coolant in the trans axle tank for circulation. Pump may have stopped working. Hal
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Is taking it to a Toyota Service Center problematic?
    Not to cop out? But that's probably your best course of action. Since what you are presenting is basically "I have the Red Triangle" but no other symptoms or codes. With nothing more to go on? Everything is pure speculation.
    The good/bad news? Is just like a cold, that becomes a flu, that become pneumonia...it's pretty likely if you have a problem manifesting...it will eventually get worse and you'll eventually get traceable symptoms.
    But I wouldn't recommend waiting until that point. And I think anyone would be rightfully nervous or hesitant to drive a vehicle 1000 miles with the warning triangle illuminated and no real idea why.
  7. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    Call around to independent Toyota shops in the area and ask them how much to get the codes read with Techstream or equivalent. That might be faster and cheaper than the dealer. It is unlikely to be the 12V, since the car was already well under way at the time. It is unlikely to be the inverter pump -- P0A93 shows up on ScanGauge. I am not sure if you should try to reset the check engine light or not without knowing what the codes are first, since you conceivably have a problem with the hybrid system that would be covered under CARB warranty.
  8. cnschult
    772
    97
    Michigan
    his car may be just under 8 years old, but he's got 120K on the odometer, isn't that over the CARB warranty coverage??
  9. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Have you had your inverter coolant pump replaced under the TSB?? As pointed out above, that's probably the most common cause of the issue you're seeing.
  10. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Nope, 10years/150k miles in CA (and other CARB states)
    JeffD
  11. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    +1 - when my inverter coolant pump failed, those were the lights I saw, eventually followed by a partial brake assist failure (more manual, unbalanced, and quite easy to lock front wheels), loss of power, and eventual shutdown as the inverter overheated.
  12. juliolopezgonzalez
    30
    SoCal
    Thanks guys, I bought the car from a used car dealer in San Diego with 77k, no maintenance papers at all, it looks like the car was sold in AZ originally, and has current OR plates since they are more affordable that CA sunshine dollar state plates. So what's applicable in this case as tsb/carb coverage?
  13. cnschult
    772
    97
    Michigan
    why do used car dealers remove everything out of the glove box, including service records?
    don't they know that they can sell a car faster and for a higher amount if they can prove service records, and yet they just throw it away, this behavior just baffles me.
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I do not think you have a CARB warranty.
    One step at a time though. Follow Seilert's advice and get the codes.
  15. fotomoto
    fotomoto Senior Member
    5,633
    3,811
    So. Texas
    This was another reason I purchased a particular used Civic for my wife's commuter. They didn't remove anything from the glove box. In fact, there was even a bill from a body shop for a minor fender bender that wasn't reported on the carfax.
  16. daniel
    14,487
    1,519
    Spokane, WA
    Maybe the car was not serviced. Better for the dealer to remove the evidence of no service and let the buyer think there's no information, than to inform the buyer that the car was not serviced.
    Or maybe the dealer pays some kid minimum wage to clean the car, and as part of that he removes everything that's not fastened down and gets the car sparkly clean.
  17. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    ...I only have speculation, but was made jealous at the 64F ambient temp reading.
    This "hot" So Cal weather made me wonder if the hybrid batt fan was clogged causing high temps on the batt.
  18. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i'd say every 4 to 5 years (minimal) you need to clean the hybrid battery fan.. when's the last time you cleaned yours? i'm going to do mine yearly or bi yearly from now on. (soo caked up last year... i figured it wasn't effective at all.)
  19. kornkob
    kornkob New Member
    128
    Wisconsin
    Because that's only true if the service records are accurate and complete.
    Also, it gives the new buyer more information during the negotiation process, which is not what they want.
    Finally, it makes it consistent. If every car on the lot has zero past information available that makes it easier to sell the cars than having half the cars have all the info and the other half having only some (or none) of it.
  20. juliolopezgonzalez
    30
    SoCal
    Never cleaned the fan, and of course dont know if it has ever been cleaned...Regarding the 64 degrees, that was La Jolla by the ocean, inland was in the mid 70s on Saturday wjtracy :)
    Dropping it off tomorrow at an independent dealer www.tlc-auto.com to read the code (free) , will report back with the good news (staying positive)
