Traction Battery - serial number
Discussion in 'Prius v Main Forum' started by syscon, Feb 9, 2012.
  1. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Is it possible to get Prius "Traction Battery" serial number that was installed from the factory?
  2. Cactus Hybrid
    Cactus Hybrid Member
    129
    46
    Paradise Valley, Arizona
    Not sure what you are asking?
  3. jdenenberg
    jdenenberg EE Professor
    3,944
    1,941
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There is a serial number on the top of the HV (traction) battery case (as well as serial numbers on each module and ECU, but that requires disassembling the battery to see). In my Gen2 Prius you can see the battery serial number it if you remove the panel above the spare.
    JeffD
  4. syscon
    syscon Member
    329
    43
    Edm. Alberta
    That is one of the most expensive parts in the car.
    If I will take to a service shop after warranty expire in few years; it will not hurt to know the serial number of the battery just to make sure it will not get swap for an older units :-/
    (no this is not a paranoia) just a precaution.
  5. Flyman
    Flyman Junior Member
    64
    Packwood, Washington
    A wise precaution. I don't know how to find the serial number, but there are few things you can totally trust in life anymore and a Car Dealer sure as heck isn't one of them.
  6. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Simple solution is to drill a hole in a box where the buttery is and put a padlock :-/ (simple and effective).
