adding DRL to a 2011
Discussion in 'Gen 3 Prius Accessories and Modifications' started by pauln64, Feb 11, 2012.
  1. pauln64
    pauln64 Junior Member
    77
    Macon, GA
    I'm thinking of adding DRL to my 2011. I was looking at this.
    Truly LED Daytime Running Light Automatic Auto DRL On-Off Switch Relay
    Reading the instructions, I wonder if this will work since the engine will be turning off/on constantly. It says that it will turn on when the engine is on and this is directly connected to the battery. This of course presents another problem since the battery is in the back.
  2. jaredy
    jaredy Member
    162
    SoCal
    do you want to drill on your grille for you LED DRL?
  3. Cyberous
    Cyberous Junior Member
    47
    Hollister CA
    I'm pretty sure this is based on the same kit I picked up in Japan a few years ago, it works off vibrations.
    I had it on my S2k
    Should work.
  4. pauln64
    77
    Macon, GA
    cool. Where to hook it up under the hood since no battery?
