mpg calculated vs computer
Discussion in 'Prius v Fuel Economy' started by alfon, Nov 4, 2011.
  1. Tomig
    Tomig New Member
    N.Cali
    First fill up... Drove 414 miles.. Computer said 43.9 . Hand calculated 42.5. Weather 40-65 traveling about 50/50 freeway and city..
  2. hoddy4
    hoddy4 New Member
    118
    NC
    Just took approximately 130 mile trip from Fayetteville NC to Wilmington NC is about 45 degree weather. Most of traveling was a between 50-55mph. Averaged over 52mpg by the computer. Nothing unusual except conservative driving.
  3. Guill
    Guill Member
    165
    Italy
    First fill-up for our v. 45.9mpg displayed by the computer; actual calculated--45.03mpg. Very, very happy with the mpg and with the accuracy of the trip computer.
  4. danbob
    danbob Junior Member
    36
    Westchester NY
    2nd full tank ever
    41.6 mpg-Displayed. 41 according to Fuelly.
    2012 v Two
    16" wheels 35psi front/35psi rear
    Just upped cold pressure to 40 psi all around so we will see what happens...
    Love it. Improved MPG by over 2mpg since first fuel up.
  5. Hankenstein
    Hankenstein New Member
    Colorado
    Second fill up, I drove 470 miles, the computer said 47.9, I put in 10.123 gallons which works out to 46.4 hand calculated.
    I drive about 50% city, 50% highway, temperatures have been roughly 30-50 F. I have about 800 miles on the v now.
  6. rcturner
    rcturner Junior Member
    53
    I log every fill and the computer is consistently 2 to 2.5 MPG higher than reality. Thus far, I have filled the tank 13 times and all but one have been at the same pump using the same process for filling.
    9watts likes this.
  7. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Same here after 11 fillups.
    However, it doesn't take much additional fuel to make the difference greater. On my last fillup, the displayed average mpg was 51.4 after driving 461 miles (I still had 2 fuel bars left). So... 461/51.4=8.97 gal. The pump stopped a around 9.2 gals which yields 50 mpg. I added another half a gallon to round the dollar amount. That dropped my actual mpg to 47.6.
    It seems that the 2 mpg difference seems about it. You can make it better or worse depending on your fill up technique.
  8. Hankenstein
    Colorado
    I reset the trip with every fill up, so far 3000 miles 46.8 on Fuelly (average) 49 on the trip meter. Every tank is consistantly 2.5 to 3.0 mpg off.
    I always lean too far towards consipiracy but I find it interesting that my 2002 Toyota Sequoia has no such problem. Surely gas fuel gauge technology can't be that different.
  9. gunkie
    gunkie New Member
    Solebury PA (US)
    I have not performed a comprehensive analysis of our new Prius V 2012, but I can tell you this: My wife is the sportier driver. I can get upper 40's mpg on a tank or single trip quite easily and typically get 50+ mpg commuting. However, my wife lives in the very low 40's mpg neighborhood.
    I filled up this morning to the 'click' and still have the receipt. I also reset the Trip-B mileage to zero. I should be able to track computed v actual mpg next time I fill up (late next week!).
  10. Wanderer
    Wanderer Hybrid neophyte
    366
    39
    Cold country
    Is your wife interested in learning a more efficient way to drive your v? She may not realize there are different techniques. I didn't until I went looking. W
  11. Mendel Leisk
    41,914
    I'm pretty much convinced the Prius mpg indicator is inaccurate by design.
  12. pardreamer
    pardreamer Member
    114
    San Diego
    After 2990 miles, 50.3 mpg computer and 48.2 mpg calculated.
    I am wondering if the gas stations gave the amount of gas stated? They could cheat by 2 or 3 percent and no one could have known.
  13. roseandandy
    roseandandy New Member
    I have noticed a difference of at least 1.5, and as much as 2, mpg in difference between what the gauge for a trip shows, and what the calculated mileage is. I have about 8000 miles on the car (purchased at the end of Jan in Minnesota). Obviously, getting MUCH better mileage in the warmer months than the cooler. I also am a conservative driver, although annoyingly so. LOL! My "lifetime" average to date is 50.1, so I figure that means around 48 actual. Can't complain about that!
  14. pardreamer
    pardreamer Member
    114
    San Diego
    Can you reset the life time average? I haven't try it yet but don't want to lose my life time average.
  15. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    Here you go.
    From the Owner's Manual
    p199: While the odometer is being displayed, or when the odometer/trip meter are not displayed, the average fuel consumption from the last reset will be displayed.
    p49: Selecting "Clear" on the "Past Record" screen will reset the past records and best fuel consumption.
  16. runukraine
    runukraine New Member
    34
    CA
    I'm averaging 41.3 on the computer... Fuelly puts it at 38.5 right now. That's after 10k miles.
  17. Cap'n
    Cap'n Junior Member
    34
    TX
    I don't have ready access to a "measured mile" so I don't know how accurate my speedometer is. However, have read of other owners checking their speedo calibration and reporting indicated speeds 1 - 2 mph greater than true. I can see a manufacturer doing this intentionally to help owners avoid speeding.
    I can also see this same error carrying over to the car's computer mpg readings. Of course, a little extra software could be used to remove the induced speed error from the mpg computer calculations, but Marketing might have nixed that extra effort. :)
    Just a thought.
  18. pardreamer
    pardreamer Member
    114
    San Diego
    I had a Garmin portable GPS in my 2008 Prius and the speed shown by the Prius was about 2 mph higher than the GPS unit when I was cruising at 65 mph. I believe the GPS is much more accurate. In addition, when I use google map to get the distance between two points. The trip distance shown by the Prii (08 Prius and 2012 Prius V) are always about 3 percent higher. I think this is part of the scheme by Auto Manufacturers to spike up their MPG. My wife's CR-V has the same problem.
    Because the odometer is likely to be juiced. Your and my calculated MPGs might not be accurate either because we rely on the odometer to track the mileage.
    Since the mileage computer is juice about 4%, and the odometer is juiced by about 3%, the total computer reading might be about 5% to 7% too optimistic.
  19. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    We have nearly 80,000 miles on our 2010 Prius. The indicated mpg readout
    has been off since day one, over reading. For the last 6,000 plus (trip A)
    miles the gauge is over reading by about 2.4 mpg. If the gauge
    indicated displays 55 mpg I alway take off 3 mpg and at 52 mpg
    that would give me a true reading.
    It would be nice if Toyota had a software fix to make it 99-100 %
    accurate.
  20. sURFNmADNESS
    sURFNmADNESS Prii Family
    199
    48
    Omaha, NE
    I have done the GPS speed trick and a couple radar, here is your current speed signs to slow down traffic in high speeding ticket zones. My wife's 06 Prius, my old 07 TCH and now the v 3 all display 2mph over the true speed. This seems to begin about 25mph and continue up from there. Maybe below 25 it is just 1 mph. Guess I need to go check that now.
