Just received Curt hitch and Swagman XTC bike rack
Discussion in 'Gen 3 Prius Accessories and Modifications' started by txl146, Feb 14, 2012.
  1. txl146
    txl146 Member
    301
    NY
    Is anyone interested in seeing pictures from the install? I plan to install 1 1/4" Curt hitch tomorrow evening, and bike rack on Thursday evening.
    Can't wait to install them.... :D
    Updated: 03/12/12:
    Stock brackets and 17mm bolts removed:
    [​IMG][​IMG]
    WolfpackBill likes this.
  2. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    Sure, I would like to see some pix. after the install. I'd like to add that I have a Curt hitch installed on my lexus suv & feel it is a quality product.
  3. bmp99
    bmp99 New Member
    Maryland
    subscribed:pop2:
  4. snakeye2669
    snakeye2669 Junior Member
    Jersey
    Yes, I looking into get the Curt hitch too.
  5. silentak1
    silentak1 Since 2005
    893
    28
    LA
    I have the Curt class 1 hitch too. I have yet to use it, it's top notch quality, did my research extensively. Now i'm thinking of selling it since I really have no use. Thought I'd tow my motorcycle one day, but i'm not sure now...
  6. artnc
    artnc Junior Member
    28
    Asheville NC
    curt hitch and swagman rack is precisely what I have on my 2010. Install was a breeze and carried a bike from Fl to NC at high speeds with no issue at all. Good idea to figure a way to secure bike to hitch since with 2 easy to reach bolts on the bike rack, it can be removed from the hitch even if you have a standard hitch lock that goes thru the hitch. good luck should be easy,....oh I bought a decent torque wrench to get the torque correct but I think you can get by without one.
  7. mark@3dyn
    mark@3dyn New Member
    San Diego
    Did you install on a lift of jackstands? I installed on our lift, which seemed like the only way to do it without removing the rear undertray. I also left off the tie down bracket on the left side. Right side was also the exhaust hanger bracket, so I needed to keep that on. I have an older Saris rack that I swap between my GTI and the Prius. I drilled and tapped for a 3/8-16 bolt to reduce the amount of play up and down, which I wish I did on my GTI before installing.
  8. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    You don't have to jack up the car, but it would be easier. Go to Harbor Freight and get the $10 extension kit. You will need two or three of them from what I remember.
  9. artnc
    artnc Junior Member
    28
    Asheville NC
    No jacking up the car and no need to drill any holes with the curt hitch I used. Simply took out the tie downs on the rear of the car, per instructions, and put bolts back in holding down hitch. Used extension for the socket wrench.
  10. mark@3dyn
    San Diego
    I watched a video about installing it, and they inserted the left side with the hitch at 45 degrees, the rotated it up to the right side. I didn't even try to do it on the ground since we have a lift anyways. I only added the 3/8 bolt to the top of the receiver just to lock down the bike rack. Might not be an issue on other racks, but my Saris is pretty loose up and down without it.
  11. txl146
    txl146 Member
    301
    NY
    Sorry guys for the delay. My wife and I decided to hold off on the install since we don't plan to go biking until weather gets warmer. Don't feel like driving around with additional 25lbs of weight.
    Will update this thread once I get a chance to install one. :)
  12. txl146
    txl146 Member
    301
    NY
    Some pictures...
    $109 shipped from eBay:
  13. txl146
    txl146 Member
    301
    NY
    Updated pictures!
  14. txl146
    txl146 Member
    301
    NY
    Finally had a chance to test out the hitch and bike rack on our trip to Cape Cod, MA over Easter holiday weekend.
    First thing I've noticed was how sturdy it felt compared to top mounted bike rack. I think it's best $260 I spent on our Prius. So far no complains!
  15. txl146
    txl146 Member
    301
    NY
    You guys will love this: :)
  16. theuglierduckling
    theuglierduckling New Member
    california
    I'm trying to purchase the same thing. Which model Curt hitch is this?
  17. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    Curt also sells a nice tray-style bike rack that is very similar. That's what I have. Love it. Only issue with a rear mounted rack is that you should move the license plate to avoid tickets. I built a lighted bracket with my 3D printer for this purpose.
