Efficiency gains in City or Highway driving?
Discussion in 'Prius c Main Forum' started by ystasino, Jan 5, 2012.
  1. Trollbait
    12,609
    CR will likely have it looking horrible mpg wise.
  2. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    I'm looking forward to seeing what hyper-milers can get out of the Prius c. Keep it under highway speeds, and it should be really good.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    CR's city test results are always (or almost always) much lower than EPA city ratings. Their highway is usually higher than EPA highway. But, due to their low city numbers, overall is usually lower than EPA combined.
  4. Trollbait
    12,609
    CR's combined also includes a stretch driving in real life traffic. If you drive traffic like they have around their test facility in Connecticut, their numbers might be helpful. But the EPA doesn't do that because it isn't repeatable. In addition to seasonal differences in temperatures with an outside test track, their is also differences in traffic loads with their test. This may give a mileage number closer to what can be expected, but their numbers for models can't be fairly compared with other models tested at different times.
    I am too. I don't the think the manual Insight has to fear losing its crown though.:)
  5. WX4GPS
    WX4GPS Junior Member
    64
    TMMK Georgetown KY
    anyone know the recommended oil on this atkinson engine?
