Help me turn off the back-up and seat-belt alarms!!!
Discussion in 'Prius v Accessories and Modifications' started by rubdr, Jan 19, 2012.
  1. rubdr
    rubdr New Member
    midwest US
    Does anyone know how to turn off the constant annoying back-up alarm in a Prius v (lowercase v for the Prius v wagon) three? I asked the dealer and they told me it cannot be done...no codes yet. I remember doing a series of settings in a Gen II Prius that would turn off the backup alarm and seatbelt chime. Any help would be greatly appreciated.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Nope, cannot be done through settings. The dealer has to do it or if it is like a Gen III, it can be done with a scanguage. Some people have done it with their scangauges on the Gen III and there are threads on PC about it.
  3. rubdr
    rubdr New Member
    midwest US
    Like I said above, the dealer said they couldn't do it. Isn't there some "sequence" like I did on my 09 prius to either turn off or reduce to a single beep??
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    No, like I said it cannot be done through settings. By that, I mean using a sequence like on the Gen II.
  5. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    http://www.toyota.com/t3Portal/document/om/OM47674U/pdf/sec_06-02.pdf
    Read this (show the first paragraph to the service manager) and check those items you would like changed.
    Now be firm with the Service manager, do not be afraid to bring in your sales man. You have a questionnaire you need to fill out on how they treated you during the sale. Explain that this is their job, according to Toyota.
  6. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    One Prius Chatter posted that he used a scangauge II to turn off the reverse beep in his Prius v. But that cost around $100. I would just bring it up next time you make a service appointment for your Prius v, and make sure that he or she agrees that it will be done free of charge.
  7. KendallM
    KendallM New Member
    Santa Fe NM
    I don't know about the three, but the 5 can be done at the dealers. At the back of the manual there is a grid of customizable settings. Both of those are listed. The dealers and salesmen don't even know about it. If you show them the manual and insist, they will get it done. All it is is a little box they plug into your computer system and change the settings from on to off. For some reason it is a secret that they don't want you to know. Keep on them. I have had it done twice, once on a Prius IIII, and on my new v fice.
  8. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    Well, to be honest, the reason they don't tell you that is mostly to avoid having to mess with the onboard systems for other drivers. The annoying alarms are there for people's protection -- IE: Usual forgetfulness.
    It's basically the 'lowest common denominator' situation. Like there are states with serious seatbelt laws. The seatbelt reminder is to reinforce people to wear seatbelts, and instead of trying to futz with different states, lowest common denominator is 'have it on'. Same with the whole backup thing, as some people do sometimes forget which gear they are in, and with the way the gear shift is on the Prius v and also the other Toyota cars, it is easy to forget not to look on the dash which gear you are in. It's sad, I know, but again, a sign a co-worker has says the following:
    Never underestimate the power of stupidity in large groups.
    I know that seems rather crude and rude, but at the same time, it is an important statement...
  9. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    I have a great idea! How about someone finding WHERE this beeper is located and we can disconnect it or perhaps there is a fuse to remove to silence it?
    LisaMcC likes this.
  10. khschmidt55
    khschmidt55 New Member
    Tacoma, WA
    I paid my dealer $50 to reduce the backup alarm to a single beep...after being told by the dealer and Toyota Cust Svc that it couldn't be done. I REALLY hated that. Trying to get the seatbelt alarm to turn off now...
  11. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Find someone with a scangauge II, or buy one.
  12. GaryP.
    GaryP. Junior Member
    Tri-Cities, WA
    I see you are in Tacoma, if you are ever over to the Tri-Cities I can do it for you with my bluetooth ELM327 device ($22 on Amazon)
  13. vofv1961
    vofv1961 Junior Member
    Houston
    Mike Calvert Toyota in Houston changed the continuous backup beep to just one short beep when you put the car in reverse. All in 20 minutes, and no charge. Kudos to them.
    I personally think it's more dangerous having the constant beeping going on while you're backing up. Totally distracting for me.
  14. Fore
    Fore Don't look back!
    494
    107
    Does anyone know if the backup beep can be turned off using an "UltraGuage"? It's similar to the scangauge II but cheaper.
  15. GaryP.
    Tri-Cities, WA
    If you can send commands then yes. I turned it off using the $21 ELM Bluetooth adapter off Amazon.com
    Here is a copy of what I posted on another topic. Maybe it will help.
    After hours of reading and multiple false starts I was able to disable the Reverse beep using my Android phone! Ha!
    Using one of the ELM-327 knockoffs from Amazon.com (2 day free Prime shipping) and 'ELM 327 Terminal' from the android store, it was a 2 minute job (that took me 20 hours to figure out).
    I did all this with the 'Ready' light on and the doors all closed. Not sure if that is needed, but just in case you can't reproduce my results.
    After the terminal program is all connected I just typed the following commands into the little white box on the bottom left of the terminal program (not clear that this is where you are supposed to type and not very big, but it works).
    Turn 'Timer' (right side of screen above 'clear') off (or commands repeat over and over again).
    Commands:
    AT SH 7c0 (hit 'Send')
    Returns: OK
    21ac (hit 'Send')
    Returns: 61 AC 00 (meaning continuous beep)
    3bac40 (hit 'Send')
    Returns: 7F 3B 78 (no idea :)
    Returns: 7BAC (meaning done)
    21ac (hit 'Send')
    Returns: 61 AC 40 (meaning now single beep)
    I then popped the car into 'Reverse' and joy! joy! only 1 beep.
    Mawesy, Damon P, MortenAZ and 2 others like this.
  16. dz302
    dz302 Prius Rookie
    South Carolina
    So, you have a SGII and have disabled your alarm? If so, please let me know because I have had a SGII for years and I read the manual and cannot find anything about disabling a seatbelt alarm. If you know how, please let me know.
  17. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    @dz302;
    Look at post #29 in this thread. It spells out the scanguage II procedure pretty good. Post #35 is good and has YouTube video.
    http://priuschat.com/forums/gen-iii...scussion/64406-scangaugeii-work-2010-a-3.html
    Post #86 on page 9 has a link to a spreadsheet of all scanguage codes. I have used a lot of Gen III codes successfully on my Prius v (wagon). I have a older scanguage with software 3.15 so there are some Gen III codes that will not work for me.
    Have fun poking around the car's computer.
  18. dz302
    dz302 Prius Rookie
    South Carolina
    Thank you. I'll poke around.
  19. mdime
    mdime Junior Member
    SoCal
    FYI, to disable the seatbelt beep you can use Gary's instructions with a few simple changes (I forgot to write down some of the return info that he had):
    Commands:
    Returns: OK
    21a7 (hit 'Send')
    Returns: 61 AC C0 (meaning beep enabled)
    3ba700 (hit 'Send')
    Returns: :confused:(forgot to write down)
    21a7 (hit 'Send')
    Returns: 61 AC 00 (meaning beep disabled)
    -Mack
    MortenAZ likes this.
  20. sgbgla
    sgbgla New Member
    New Jersey
    I had my other Prius IV changed to one beep and when I got the Prius V model 5...I was told it couldn't be done. I insisted it could be done and well....they did change it....you have to insist that they do it...and it should be free.
