Hi folks. What gas mileage will i get 70-80 on i-95 eastern nc, sc, georgia. Thanks
Discussion in 'Gen 3 Prius Fuel Economy' started by BEENMB, Feb 19, 2012.
  1. BEENMB
    BEENMB New Member
    U.S.
    Hi folks. What kind of gas mileage do you think i'll get with a 2012 prius 4, no sunroof with the cruise control on cruising 70-80mph on i-95 eastern nc, sc, georgia. Ie pretty darn flat. Thanks, b
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Giving an exact number is hard but with cruise at that speed, flat road about 49give or take 2mpg.
  3. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    42-48mpg calculated.
  4. BEENMB
    BEENMB New Member
    U.S.
    Awesome. I was wondering about those EPA numbers. Thanks Mark
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    70 is much better than 80, varying between them would be worse than either.
  6. Gary Otto
    Gary Otto Member
    123
    Silver Springs, FL
    Before or after the speeding ticket?
  7. BEENMB
    BEENMB New Member
    U.S.
    FYI for folks driving on I-95 in nc, sc, georgia. I travel that interstate a lot, have for several years. The speed limits vary between 65 and 70. If you go no more than 8 MPH over the limit the troopers will not bother you.
  8. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    I was going to say 55.
    Of course, it is possible to drive with a heavy foot and bring that down to 50.
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Which lane ?
  10. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    It also depend on road condition, wet roads will effect your mpg by
    as much as 5 mpg. Wind has an effect as well. A tail wind will
    get you more mpg a headwind you of course will get less.
    Also one way runs are not the best way to compute true highway mpg. The best way is a round trip on the same road.
    Temperature is another factor. In summer at 75 mph you may get a
    true 45 mpg in winter maybe 40.
    Also gas blend, winter blended gas has less heat energy than summer blend. Also 10% ethanol will lower your mileage by as much as 3 mpg.
    The best way of course is to just try it round trip.
  11. bisco
    51,840
    nice graph jim, looks like 75 is the sweet spot! we go thru there every winter in our hycam on the way to florida and back. it's probably the best place i've evr driven for great mpg's.
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  13. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I average about 45 mpg running 70-80 on I-40 from east to west NC with cruise so should be very similar to I-95.
  14. Mendel Leisk
    41,315
    Stay legal and you'll see a marked improvement. The Prius does not shine on the highway, and the more you push it the more mileage tanks. It's one place a carefully driven Civic Hybrid can surpass it.
  15. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I've never seen 55 mpg at 70-80 mph. From when I took a trip to California & back which was 2k miles of travel on I-5 doing 70-75 mph with CC set I got 43-47 mpg & at 60-65 mph It went up to 50-55 mpg when I was traveling through Oregon. ;)
    My guess would be 45 mpg +/- 3 mpg when traveling at 70-80 mph.
  16. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I did a trip to NY-Long Island over the Thanksgiving holiday 2011, mostly I95, used CC where possible and traffic was flowing. Avg calculated mpg came to slightly higher than 52. Kept up with traffic but I usually don't try to be the fastest car on the road since I usually catch up to everyone passing by at various congestion points along the way. Typical CC set at 72-75 and partial grill block.
