Synthetic Oil
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by hoddy4, Feb 20, 2012.
  1. hoddy4
    hoddy4 New Member
    118
    NC
    Is it better to use the synthetic oil at 10000 mile intervals or regular oit at 5000?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  3. silentak1
    silentak1 Since 2005
    893
    28
    LA
    I do synthetic every 10,000 miles, per owner's manual. Even at 10k and driving in LA, it still comes out relatively clean using the OEM filter + dealer supplied synthetic oil (it's a japanese brand, the name is at the tip of my tongue).
  4. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Eneos?
  5. ataylorracing
    ataylorracing ataylorracing
    171
    29
    Fishers, IN
    Stay away from synthetic blends...they can have as little as 20% synthetic!
  6. Mendel Leisk
    41,824
    I like synthetic 0W20 at 5000 mile interval.
    In Canada the Owners Manual calls for 0W20 at 8000 km (roughly 5000 miles) or 6 months, whichever comes first. I'm in the south west corner of the country, temporate coastal climate. Drive maybe 100 km to the south, into Washington State, same climate, but the interval is double.
  7. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    I concur synthetic oil 0 W 20 at 5 K intervals. ^^
  8. vlady
    vlady Junior Member
    42
    Issaquah, WA
    synthetic at 5k interval is not wise, 10K intervals based on driving style/conditions. I use synthetic blend in other car with 6k interval without any issues. Nothing wrong with syn. blend
    I will go with 5K during "free maintenace" and stick to 8-10K interval
  9. danbob
    danbob Junior Member
    36
    Westchester NY
    How come everyone on here uses 0w20? Does it really make much of a difference compared to standard synthetic?
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It is the only weight Toyota approves.
    (same page of the manual I linked to in the very first re[ly)
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    From what I have been able to find there is no technical reason having to do with engine life etc. The reason is based on an EPA rule that the oil required by the manufacturer must be the same viscosity as the oil used during the EPA mileage and emission tests.
  12. The Critic
    3,193
    2,333
    CA
    And since the oil appears to be adequate for most Prius drivers, why not use it?
  13. bluesparky
    bluesparky Prius v -Five ATP Blizzard Pearl
    Troutville, VA
    Where I work, we overhaul diesel fuel injection as well as most major makes of import diesel engines. The newer engines have much closer tolerances between pistons and cylinder bores due to hydrocarbon emission standards (they do not want the oil that lubricates the cylinders to be burned in the combustion stroke and come out the exhaust), and the bores are no longer honed with stones, but are computer machined with diamond hones. The honing marks are also diamond "de-burred" in a process which no longer requires rings to have to "seat" into the cylinder walls as they did in older engines. The angles of the honing marks in the cylinder walls are set in at such an angle that it provides the proper piston/ring lubrication when using the exact specified weight of oil, not leaving too much oil left in the honing marks on the cylinders which would be burned. You'll see that technology sometimes on the shows such as "How It's Made", "How'd they do that?", etc...:)
    n0na likes this.
