'12 Prius III auto headlight shut off?
Discussion in 'Gen 3 Prius Main Forum' started by autopc, Feb 17, 2012.
  1. autopc
    autopc New Member
    57
    midwest
    Have a '12 Prius III. It looks like it does not have a auto shut-off for the headlights. Will the headlights turn off via a safety type feature if I accidentally forget to manually turn off the headlights? Any harm in that? Any way to install a headlight auto shut-off?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    30 seconds after turning off the car it turns off the lights
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Also, don't test it by turning them on while in the ACC mode. You must turn on the headlights while the car is in the ready mode (running) for auto off to work.
  4. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    I have a 2012 2 and I can change the headlight off setting via screen. I set it to zero, headlights do not turn off when you turn off the car but when opening the drivers door.
  5. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Cool to hear that it's now user-configurable. It used to be a dealer-configurable option.
  6. shawntprice
    shawntprice New Member
    Indiana
    If you can set the lights to automatically turn off when you open the driver's side door, would there be any reason to not just to leave the headlight knob turned to 'on' all of the time?
