The gas cap is...
Discussion in 'Gen 2 Prius Main Forum' started by jmann, Dec 9, 2005.
  1. on the correct side.
    0 vote(s)
    0.0%
  2. on the wrong side.
    100.0%
  1. jmann
    jmann Member
    201
    30
    Cleveland, OH
    Does toyota not respect the "foreign side" (right side)? Oddly enough, my american Grand AM, has the cap on the foreign side! every other pontiac I have ever seen uses the american side (left).
    What's up with the sides thing? It doesn't work anymore.
  2. roach52osu
    roach52osu New Member
    200
    Dublin, Oh
    I like it on the left since that is the drivers side here in the US? Is the fuel door on the pther side on RH drive Prius or toyotas or still on the left? Anyone know?
  3. wilco
    wilco New Member
    402
    My Corolla and Tercel are/were also lefties, my Toyota truck was a righty.
  4. StuartS
    StuartS New Member
    34
    Carlisle, UK
    UK Prius caps are on the left. It's a standard body shell.
  5. sunnysandiegan
    sunnysandiegan New Member
    248
    We just test drove an '06 on Saturday, but I do not recall where the gas cap is... I probably assumed it is on the driver's side, like my '95 Corolla and DH's '04 Camry...
  6. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Some time ago there was a puzzle on Car Talk that had two attendents at a gas station guessing on whether a driver came up with the correct side by the pump. One guy was nearly always correct. The answer to the puzzle was that this guy would notice the car's exhaust. The gas fill pipe is nearly always on the side opposite the exhaust.
  7. Alrobot
    Alrobot Junior Member
    La Verne, CA
    My 65 Mustang Fastback has it in the middle of the rear. I think this is the correct spot for it.
    Al...
  8. Twiddles
    Twiddles New Member
    47
    Downstate NY
    I wish they would have put it on the other side=shorter lines at the gas station.
  9. aaf709
    3,862
    2022 Prius Prime
    My father's 1964 Plymouth Fury had it there too. It was hidden behind the rear license plate. It's a very convenient place for it to be. :)
  10. Tideland Prius
    16,587
    Works for us on the driver's side and works in Japan with full service and RHD lol.
  11. tunabreath
    tunabreath New Member
    226
    Southern California
    When I opened this thread, I thought the poll choices would be "left" and "right", and that the point would be that Prius owners don't buy gas often enough to remember.
  12. engunneer
    engunneer Member
    307
    Medford, MA
    2020 Prius Prime
    You should look at wilco's avatar above. The Icon for the gas pump has an arrow pointing to which side it's on.
    Another random fact brought to you by a Random engunneer
  13. QED
    QED New Member
    267
    Sunny Hawaii
    Yea, why DON'T they put the gas cap in the middle.
    Then you can glide up to either side of the gas pumps. :p
  14. hockeybrat
    hockeybrat Member
    127
    My 92 Camry has the fuel door on the left side.
  15. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I'd rather have it on the right side. Most cars in the US have it on the left side so when filling up in the summer at busy gas stations there's usually less of a line at the pumps for right fill side vehicles. Yeah, you could turn around but some stations on the parkway etc are 'one way'...
  16. naterprius
    naterprius Senior Member
    1,843
    The correct side for fuel doors is CURBSIDE. That way, if you run out of gas and pull over, you are not standing out in traffic with a gas can. VW touts this as a safety feature.
    However, this isn't much of an issue with a Prius, if you run out of gas, you can just drive it to the gas station and fill up.
    Nate
  17. slortz
    slortz New Member
    316
    I like it on the driver's side. Don't have to walk around the car to the passenger side after pulling up to the pump. Call me lazy. :p
  18. longjohn931
    longjohn931 New Member
    116
    Orlando, FL.
    Really doesn't make any difference, most gas pums have a long enough hose to reach the far side, just pull slightly past your grade and stretch across the back, whats the big deal?
  19. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
    Having two cars with the tanks on different sides is confusing though. I'm always driving up to the wrong side.
    Our Honda is on the left, and the Subaru is on the right -- both Japanese too.
  20. tochatihu
    tochatihu Senior Member
    9,828
    3,796
    Kunming Yunnan China
    2001 Prius
    Way back in the days of classic Prius, fuel fill was on the passenger (US curb) side. Could not tell ya why they switched. The 12 v battery also switched sides with the model change.
