2007 Low MPG -- Can't figure out why
Discussion in 'Gen 2 Prius Fuel Economy' started by scramjett, Jan 23, 2012.
  1. scramjett
    scramjett New Member
    61
    Sacramento, CA
    You're welcome! Maybe one of us will come up with something! :)
  2. scramjett
    61
    Sacramento, CA
    Hmmm, an interesting thought. I had the tires put on by America Tire Co so they may have done something odd that might cause drag. It didn't go unnoticed by me that the problem started around the time I got the new tires. Maybe I can take it back to them and ask to check. They are pretty cool about that sort of thing. :cool:
    Sounds like a good idea. Does it plug into the data port under the steering wheel?
  3. scramjett
    61
    Sacramento, CA
    Yes, I can safely say that the MFD is just one of several symptoms. It used to be that I could get from where I live to SoCal (Glendale area, approx 370 miles) on one tank of gas. I would have one pip (not flashing) and sometimes two on a good trip by the time I get there. I've only had to stop a couple of times before getting there to refuel, but that was in Gorman (approx 300 miles from home or 60 miles to my SoCal destination with 2 pips left). Now I get more like half way (Kettleman City, approx 200 miles) and I'm already down to 3 pips!! It used to be I would still be at 5 pips by the time I get to KC.
    Another oddity is filling the gas tank. It seems like lately the pump clicks off sooner (any pump regardless of gas station, even the one I use regularly). When I first got it, I would top off (a habit I quickly broke) and only get maybe another .1 or .2 gallons. Just to see, I topped off while I was in SoCal and I got more than a half gallon (around .7ish) in before I stopped. I might be just splitting hairs, but it seemed strange to me.
    I should note that it didn't solve my gross mileage problems, it just made it so that on the trip back, I made it to Stockton (320 miles from SoCal) before the last pip started flashing. I might start topping off before my long trips just so I'm not having to stop half way anymore.
    I don't know if this is related to the mileage issue. I didn't think it was so I just dismissed it until you asked.
  4. scramjett
    61
    Sacramento, CA
    Same here. Most of the time, when I'm not using the Nav, it's just on the "bar chart" economy screen. I only put it to that screen on the grapevine because for me, it was fun to see all of the arrows pointing to the wheels. Never had the dash light up like a Christmas tree. Being a Prius, don't think I'd want it to either.
    I've been using it more lately in an effort to diagnose the problem by monitoring the cars behavior. Don't have anything as sophisticated as a ScanGauge (yet).
  5. scramjett
    61
    Sacramento, CA
    No worries. I would have answered anyway. As you pointed out, it's a long thread (much to my own surprise) so I wouldn't expect folks to either a) remember everything or 2) read the whole thing.
    Can I get those at any auto parts store or do I need to special order them? What are their costs?
  6. snowhound2
    snowhound2 New Member
    Indiana
    I haven't noticed any other issues but I haven't started digging into it yet. Being a compulsive researcher type, I look for where to start out here on the posts. As for what I have seen - my regular 80 mile round trip commute has a shallow hill that is not that long (best guess 1/4 mile long, no guess as to grade but not a really steep grade). MPG has dropped from 20ish on the uphill @55 mph to 10ish @ 55 mph and minimal battery assist; I didn't notice exactly when (most likely a 1.5 wks ago) since I don't pay attention until refuels. Rest of drive is relatively flat so I don't notice as much of a difference but looks to have slid 4 or 5 mpg, will know better when I cross check MPG at my next refuel. Coming up on a maintenance check time so I will have things gone over then and in the mean time check the same things in this post prior to servicing at the dealer. Will post if something changes.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  8. chuckokie36
    chuckokie36 chuckokie
    longview, Texas
    I have a 2007 Prius touring and have been experiencing a drastic change in my MPG for the last year. after trying every thing I read on Prius chat with no luck,I checked my 12v Battery, low and behold the voltage was low. I replaced it myself with the new Yellow top optima battery and my mileage jumped back up into the high 40s around town---- it was running as low as 32 MPG
  9. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    Scramjett: I read thru the first page and the last three pages of your thread. Based on my '07 HCH failing hybrid battery pack experience, I'd say your battery pack is past its 'best before' date.
    I'd get a ScanGauge, set it up with some extra gauges (see x-gauges for dummies thread) that show:
    • the battery SOC (shop manual states '60%' is its happy zone). You can drive and watch the Prius software 'sine wave' its way above and below the SOC 60% with a good battery; and
    • cell SOC delta. It should read "0" %. If not, one (or more) cells is out of balance.
    Out of balance cells seems to be an issue with the HCH II based on my experience (and chat room rants).
    If your five year driving a Prius habits have not changed and the simple stuff has been checked, get a second opinion on your battery pack via the ScanGauge.
    Good luck with your issue.
    Cheers
    Mike
  10. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    Torque and PriiDash are better for analysis. Scangauge is better for instantaneous readout. Mangoose is a little iffy -- a Chinese clone and hacked software copy of Techstream Lite. It depends on how you feel about things like that.
  11. Jenpa
    Jenpa New Member
    Cape cod
    This thread has read like a good novel as we drove our new/used 2007 Prius (pkg 4) with 22K miles (it lived on Nantucket) from Cape Cod to Indiana in the last two days. Since buying the car (from a Toyota dealership) last Monday, I have wondered if it was working optimally. Once I found the display screen I noticed it had gotten on avg 27mpg for it's previous 105 miles!! I was shocked and had immediate buyers remorse until I drove back to the dearlership 60 miles away and got nearly 50 on the way. They told me the car would need to cycle through 2 tanks of gas and "get used to me as the new driver" before I could honestly gauge it (all the while knowing I was about to take a trip across the country!)
    When I got back to where I live, I got only low 30's around town and took it back again. I was taken for a ride (no pun intended) and told how to drive the car. Well, it seems this car runs optimally when driving 30-55 mph. Below 30mph, which is what I drive around my small town, yields pretty bad mpg. AND, on the highway for the last two days, we got 32-33-35-36 for the four tanks it took to get here (1,029 miles). Granted, we have a Yakima on top and we were driving into strong winds, and after we read the thread we checked the tires which were at 32psi, front and back.
    I'm feeling like we need more time with this car, but I am strongly cautious and I am keeping meticulous track of what's happening. This thread was so inticing because we were also wondering why the engine doesn't use the battery more. The battery is constantly in the 7 bar green zone. Up hill it charges the battery and the arrow coming from the battery just occassionally blinks, which makes me think very little energy is used from it. Also, it has a really hard time picking up. I was leery to pass people because I couldn't gather speed quickly enough in the fast lane. Again, I wonder if this is a symptom of the luggage rack and wind, but still, it just seems low (and honestly a bit disappointing considering I could've bought a gas-powered engine that might have given me better mpg). That said, I was sad to see there wasn't a resolution. I will keep checking back in to see if there is one, and in the meantime I'm having a health check done here tomorrow morning at which I will be armed with a lot of knowledge, thanks to you all!
    I do have one question for the originator of this thread: What do you get driving small trips under 30mph? Is that why you got the Nissan Leaf, because the Prius didn't live up to your expectations? Thanks
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    This is not expected. The only benign explanation I can think of from my experience is that the battery icon was slow to update.
    The dealer statement that it takes two tanks to 'learn the driver' is BS.
    Overall, your fuel economy is way below average. I suggest taking off the yakima and going for a round trip of about 20 miles at 60 mph after the engine is warmed up. Anything below 50 mpg suggests a problem. Important --, try the test on a day without wind. You have to remove as much as possible driver and enviro variables to concluded something reliable about the car.
    The most common car problem with the symptoms you describe is an old 12v battery. If it is older than 2 or 3 years old, I suggest you replace it now and see how things are.
  13. seilerts
    3,326
    1,518
    Santa Fe, NM
    The Yakima will kill your mileage.
    50 mpg is a little optimistic. You may need a couple tanks of gas for the car to break YOU in.
  14. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I didn't think the Techstream Lite was a hacked version. It was essentially an evaluation version unless you registered it (or found a bypass to make it appear as registered). You can also sign up for the 2 day $55 version and download the current version of TechStream Lite if you wanted to. The Mangoose cable works just fine for the few things I've used it for thus far.
    I also have a separate TS compatible cable that can be used, but it only has drivers for Win XP (I'd have to find that driver disk again).
    Jeff - If you meet up with Justin to try to trouble shoot, I could loan out one of the cables if you get TS. It might allow you to more easily monitor more information (I haven't used it yet for that, but I'd recommend a 2nd person in the car using the laptop).
  15. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    As a neophyte to the Prius, I did a quick web search of PriiDash to see what that was all about and found this:
    PriiDash(TM) - Enhanced Instrument Panel and Data Logger for the Prius and more
    Awe inspiring to say the least, but not for the (like me) computer tech faint-of-heart :eek: (IMO).
    One question with the sample (temp) gauges I see in the above link: what data is used to constitute the displayed "water temp overheat"?
    Is it based on shop manual numbers?
    Only reason I ask is this: icon of temp gauge seems to indicate 'overtemp' (i.e. red zone of gauge) at 195F (90.6C) yet shop manual 'thermostat calibration' seems to indicate thermostat not fully open until 93C (199.4F).
    Thanks
    Cheers
    Mike
  16. fuzzy1
    10,500
    The 27 suggests many short drives without full warmup. That would be expected of both Nantucket and of car lot test drives.
    Below 30 mph in my large metropolitan area, my 2010 can do fantastically well, 70+, when Spring arrives. (Translate that to 65 for a 2007). But as a new driver, you likely haven't yet learned how, and in a small town, it may not get sufficiently warmed up to achieve this. And the best mpg season has not yet arrived. But it will still crush a traditional non-hybrid, which also does terrible under the same conditions.
    Strong headwinds and external racks hurt separately. Together, they are killers.
    Please name one that would get better mpg with the top rack into the wind.
    Since I learned to hypermile, my old Subaru gets above 30 mpg in standard conditions. But four days ago, with a fully loaded ski rack (probably smaller than your luggage rack) into a strong headwind, I couldn't hold it above 22 mpg. The same increase in fuel consumption would knock a 45 mpg Prius (the EPA highway rating of your car) down to 29 mpg.
    In additional to your conditions and style, there could still be some factors with the car itself. For more help, please read and answer this: Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new
  17. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    Found this interesting article 'predictive battery failure analysis':
    Predictive battery failure analysis for the Prius Hybrid
    In the authors opinion:
    I think (please correct me if I'm wrong) that the x-gauge "cell SOC delta" could be the 'first quick check' to determine battery health.......
  18. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Agree w/all of the above. I find it impossible that any currently sold non-hyrbid, non-PHEV and non-EV would get better mileage w/a roof rack on top, in the same conditions, under-inflated tires or not..
    Actually, that poster should answer http://priuschat.com/forums/gen-ii-...-answer-these-questions-esp-if-youre-new.html, which is almost the same. Otherwise, we're wasting time making guesses. First step is to get rid of the roof rack and box completely so that we have somewhat of baseline and 2nd is to properly inflate those tires. 32 psi all around is too low. For a non-Touring Prius, I'd go at least 38 psi front and 36 rear.
  19. fuzzy1
    10,500
  20. scramjett
    61
    Sacramento, CA
    Hi Jenpa,
    LOL - I assure you that was not my intent when I first started this thread over a month ago (has it really been that long?). But if it can help others, then at least something good will come of it even if my problem doesn't get solved.
    I've found that to be true of most cars, Prius or otherwise. For my old Saturn and Mazda 3, I would get optimum mileage at about 45 - 55 in 5th gear (took me a long time to train myself to stop driving 45 in 4th gear). This is, of course, without stopping. Stopping and going at such high speeds will also kill your mileage, especially if you're like I used to be, a competitive traffic light starter! :D
    As others have mentioned, that is probably due to multiple short trips around town in the cold winter. You'd think hybrids would do better in town, but I've discovered through both research and experience that at higher city speeds (ie 35+ mph) you're better off having it in EV mode briefly but letting the engine stay on and running in its optimal RPM (which will yield some pretty high MPG numbers).
    Again, as others have mentioned, the high winds and Yakima were probably killing your mileage. I don't have a roof rack and have no desire to ever get a roof rack (if I can help it).
    I'm thinking this is the key part here. You just got the car and bought it used. Used cars can have all kinds of idiosyncrasies that take getting used to. I bought my Prius brand new and have driven it for years without problems. I'd probably guess that my lifetime average is somewhere around 45 to 46 MPG, I could go higher if I drove the speed limit, but driving the speed limit in California is hazardous to your health. Even when the problems started, I spent two months and a couple of trips making sure the problem was not just a fluke and that it was repeatable before I came to the forum. I'm not trying to be critical or anything, I'm just emphasizing the need to spend some time with it, get to know it better, learn it's idiosyncrasies, try a few different strategies and see what the result is. I wouldn't be surprised if you'd find an improvement in mileage as a result. And of course, you'll probably notice a considerable improvement when the warm weather hits. Our winters are relatively mild so we don't really experience too many of the cold weather problems that the Prius and, really, all cars have.
    That's good! It'll definitely help!
    Well, while my car is doing the 7 bar green zone thing, it is doing it on the flats as well as the hill. It's been my experience that a properly operating Gen II Prius should be at the top of the blue zone (6 bars) when you drive on a flat highway. In your case, it sounds like the Prius is "saving itself" because of the high winds and heavy loads. I have seen that kind of behavior on hills before but generally its when the temps are around freezing. I considered that possibility but that was not the case for my President's day trip.
    LOL - That makes two of us! :)
    I don't have too many trips under 30 mph. We live in a "typical" California suburb where the speed limits are around 45. The few times (before the problems) that I did, I averaged around 50 MPG, but that was usually wiped out when I got back on the main higher speed roads.
    As for the Leaf, I put us on the waiting list for one long before we were having these problems. I mostly decided to get it because we were not using the commuter buses anymore and had started commuting by car regularly (long story). I decided that if we were going to commute on a regular basis, then we'd get the ultimate commuter car, a non-gas using EV. The Leaf was a no-brainer because it is (and as near as I can figure, remains) the most affordable EV on the market. We're doing a 39 month lease because we can take the tax credit straight off the top and I figure that when the lease expires (Jan 2015) our options will change and we can either start taking public transit again, get another Leaf, or maybe something better.
    As an aside, if anyone has any questions about the Leaf, I'd be happy to answer them. You can either email or PM me so we're not going off topic in this thread.
