Tire/Wheel Calculators
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Tempus, Dec 9, 2005.
  1. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Lots of questions about Tire/Wheel combos.
    Here's a couple of links that may shed light
    Tire and Wheel calculator
    Lets you compare tire changes
    Another Tire Calculator
    Yet Another Tire Calculator
    Tire AND Wheel Calculator
    This one will handle Wheel (Rim) changes as well, and will give you clearances if you change offest, which is nice.
    Offset Only Calculator
    For the record, Stock US Prius wheels are 15 inch diameter, 6 inch width, 45mm positive offset.
    5x100 Lug Pattern
    Weight 6.5 KG (14.3 lb)
  2. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Thanks for the links. I was just about to search for one. I usually end up using the Miata page one, but that first one is MUCH better.
  3. LionKing
    LionKing New Member
    Tempus, do you know what is the widest we can go, I'm geting 18" rims but most common tires are 225/40/18 but somewhere I heard 215 might be the widest we can go. you have any info. Thanks...
  4. Tempus
    1,690
    Washington DC
    I'm afraid I don't know the clearances on the Prius. The Tire/Wheel calculator I linked to will give you the change for your proposed wheel/tire combo, but if that will bump up against the wheel well I couldn't say.
    I know the Tire Rack guys made a list of wheels that were accetable and they might know.
  5. afternoonnap
    afternoonnap New Member
    33
    Ontario, Canada
