Prius Plus - Spring and Rear Sway Bar
Discussion in 'Gen 3 Prius Accessories and Modifications' started by EdyJun, Feb 29, 2012.
  1. EdyJun
    EdyJun Junior Member
    58
    Los Angeles
    Anyone know where I can find the best deal on the Prius Plus springs and rear sway bar?
    I have a 2010 Prius II and live in SoCal.
    Prius PLUS Packages
  2. ewilke
    ewilke Junior Member
    33
    socal
    I would be interested also.
  3. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I bought the PP RSB at a local dealer for $220 which was the best I found. I ordered Eibach springs instead of the PP springs for a great deal of around $165 after the rebate. :D
  4. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Check your local dealership.
    MB860 ?
  5. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Here are the P/N's and the prices I got here in Honolulu, these should put you on the right track.
    PTR07-47100, Plus Lowering Springs, List $349, Net $314.1
    PTR11-47010, Rear Sway Bar, List $279, Net $251.1
    Posted from my iPhone via the Tapatalk app.
  6. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    How much do the PTR07-47100 springs lower the overall stance? I would assume it wouldn't be so low as to cause rubbing on 17's.
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    It won't cause you to rub unless you go with very wide wheels or some goofy wheel offset. Sometimes hellaflush can cause hellarub if you're not careful. lol
  8. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    PTR07-47100, Plus Lowering Springs$198 PTR07-47100 - OEM Toyota TRD PRIUS LOW SPRING
    ditto on Eibach.
    Anyone knows reasonably priced good shocks for Gen3?
  9. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    I'm looking to get either the TRD or Tein springs. Leaning more towards the TRD since I can get a good deal on them but everyone I ask about the lowering has no idea...some say 1.0 some say 1.5 all around then others say nothing at all...?
  10. WE0H
    WE0H Senior Member
    3,247
    528
    It is 1.1" front & 1.3" rear drop. This is from the Toyota site description of the Plus package.
    Mike :tea:
    2 people like this.
  11. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Can I still use the stock shocks/struts for the TRD springs?
  12. WE0H
    WE0H Senior Member
    3,247
    528
    I have not read anywhere that the Plus struts are any different than stock. So if that is true then yes you are fine running the TRD springs on your existing struts.
    Mike
  13. MD80
    MD80 New Member
    32
    Owasso OK
    Does anybody know if you need to order two these part numbers to install the sway bar? There was a guy selling the sway bat on ebay that listed two parts numbers. One seemed to be the bar and the other a kind of installation kit. I can't find it now cause I guess he sold them all.
  14. MD80
    MD80 New Member
    32
    Owasso OK
    There was this part number PTR11-47010 and one othere one.
  15. MD80
    MD80 New Member
    32
    Owasso OK
    Whoops search is my friend, found it PTR11-47011
