Ottonavi Head Unit works fine with JBL Sound System!
Discussion in 'Gen 3 Prius Audio and Electronics' started by glennhl, Sep 30, 2011.
  1. teiresias
    teiresias Junior Member
    61
    Hampton, VA
    I've been meaning to do a video "review" of this new Ottonavi unit, it's just every nice day happens to be a work day, and every off day is freezing, so the last thing I want to do is sit out in the car recording something.
    Still, I think I'm going to do it, because there are a few UI tweaks that could be done fairly easily to make the iPod interface far more easier and safer to use on the unit, and I'd like to just illustrate them.
  2. rkalbo
    rkalbo 2024 XLE
    83
    Huntingburg,IN 47542
    2023 Prius Prime
    this will work with jbl its built in to support it.
    when removing the radio you need to turn the stock radio to 75% volume then remove radio and install our unit so the factory Jbl amp can be set into sink mode prior to installing hope this helps have a nice day.
    This is the Email they sent me when I asked about the Jbl and xm guess you can't use xm with it. Haven't decieded what I want to go with is the one on ottonavi site the same as the one on newegg.com cheaper there say's sold by ottonavi not the same model number on it there G2
    Newegg.com - 11-12 TOYOTA PRIUS IN DASH DOUBLE DIN 7 INCH TOUCH SCREEN GPS NAVIGATION MP3 MULTIMEDIA RADIO G2 MODEL
  3. Bulle
    Bulle Member
    378
    Looks the same to me. But at a better price.
    Ottonavi changed their web site recently; this unit used to be called G2.
    There was also a G1 before.
    Now they only sell the G2 but for some reason they removed the G2 in the title.
  4. glennhl
    glennhl Member
    175
    Arizona
    I just got back from a road trip with the Prius. The other people in the car stated several times how good the Stereo sounded. Plus the Nav got us out of a couple of jams.
    I have to say now that I've upgraded to V9.02 and taken out the Scosche adapter that the volume balance between the radio and the IPOD/DVD is not as bad as it once was. When I swapped to the Radio it was just slightly louder, not a lot. Great unit!!!!
  5. PaJa
    PaJa Senior member
    678
    114
    92
    Czech republic
  6. teiresias
    61
    Hampton, VA
    Who should I email to get the files to upgrade to V9.02? I guess I need both the actual firmware file and some kind of upgrade utility .exe?
  7. Bulle
    Bulle Member
    378
    Just ask Ottonavi. Contact us | OttoNavi
    They are usually pretty quick.
    They should send you 4 files (instructions, firmware and two .exe files)
  8. savegas52
    savegas52 Junior Member
    65
    ONTARIO CA
    had him run the update but his mcu still shows 9.00...unit restarted and everything not sure whats going on
  9. Bulle
    Bulle Member
    378
    Worked for me and Glenn.
    Was there any error messages?
    What are the exact names of the files you put on the SD card?
  10. rkalbo
    rkalbo 2024 XLE
    83
    2023 Prius Prime
    I sent ottonavi a email this morning asking if the unit on newegg is the same one there web site then I decied to call them while I was at work they switched me to Daniel they said he was in charge of the newegg.He told me the new egg was the older G2 and the one on there web site was newer.Got home got there email they said they only have one model. Does the one on the video just put on this post have any different features than the one you guy have?
    Yes, we only have one kind of Prius unit in stock right now and that’s the G2 model. You can buy it from either places
  11. Bulle
    Bulle Member
    378
    Looks the same as the one I have; must be a G2. Newegg also.
    The *older* model had a very different UI.
  12. Bulle
    Bulle Member
    378
    Hi Teiresias,
    did you get any chance to work on the video yet?
    I'm curious as to what kind of tweaks can be done...
  13. teiresias
    61
    Hampton, VA
    Sorry, no, the weather seems to be horrible and cold on my days off and nice on my days at work. My want to sit out in the cold doing a video has been pretty low.
    They're mainly UI issues in the iPod interface that I have some ideas for (nothing that involves new graphics or anything or even changes what needs to be queried from the iPod), and a few things about the general radio. Obviously, these are tweaks that would have to be done at the code level of the actual iPod interface app and front-end, so it's not really something that could be done by someone just mucking around in the WindowsCE install. I'll have some time Sunday, so if the weather cooperates I'll make a point to get to it.
  14. Bulle
    Bulle Member
    378
    OK thanks.
    I was wondering if may be you had find a way of changing the UI a bit.
    I will dig into it and see what I can find...
  15. ephatch
    ephatch New Member
    Largo
    I am really interested in this unit. Can you folks tell me if the factory XM works with this unit?
  16. Bulle
    Bulle Member
    378
    Nope. Not this one. But it's a fine unit.
