First day with my Prius Plug-in
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Tracksyde, Mar 2, 2012.
  1. daniel
    14,487
    1,519
    Spokane, WA
    I understand this. I was just pointing out that as a nation we have painted ourselves into a corner. And now, rather than trying to move back to a paradigm of less driving, we wring our hands about how nasty the oil exporting countries are, and we spend more on oil wars than it would cost us to reposition our energy consumption.
    I was not referring to you in particular, and I'm sure there are individuals who really cannot change overnight. But as a nation, changing our commuting habits has to be part of the solution.
    Bigger battery.
  2. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    The Volt qualifies for the $7500 because it is an Extended Range Electric Vehicle. With over 500 cars on Voltstats.net with 3.2+ million miles with 70% of those miles on electric (I personally have 86.4% EV miles) I think it is safe to say that it qualifies for the fuel credit. The simple answer would be that it is based on battery capacity, but for me the Volt has more than proven itself.
    I think the PiP should qualify for more based on overall efficiency, but since the credit itself is based only on max capacity like Daniel said that is why the PiP only gets $2500. Granted I am impressed to see you guys in colder weather getting 13 EV miles out of the car. At 50F I am usually at 39-42EV miles with the 10.3kwh usable in the Volt. So to see you guys getting 13 out of the 4.4kwh is impressive. That means you have a lot of room for improvement as you are only getting 2.9mi/kwh. If you can even get up in to the mid 3's to low 4's you will be all set.
    As far as regen goes as DrInnovation said it is not 100% brought back. It is enough in some cases to zero out your acceleration (in the Volt I can nearly get enough back to cancel out the energy I use to re-accelerate to speed). So rolling downhill will not create equal energy to go back up the other side. To create a lot of regen energy you would need to be doing heavy braking as if stopping and all would be lost accelerating anyway. It is an interesting phenomenon I have played with in the Volt as I go through the tunnel everyday. On average @ 55mph I may get 0.1kwh going down into it on the one side, but use about 0.5-0.6kwh to go back out the otherside at the same speed. So regen does help, but it is a very small part of the equation. On average I can go 1 mile for every 0.24-0.27kwh consumed. Is just all about maximizing your efficiency, but as Daniel said not at the expense of other drivers (they tend to get pretty mad). Anymore I just keep up with the flow of traffic.
  3. john1701a
    john1701a Prius Guru
    12,802
    5,286
    57
    It's unfortunate the total amount of money available wasn't taken into consideration. Triple the number of new owners could benefit then.
    In other words, if the same quantity of Volt were sold as PHV, it would require three times as much to fund.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
  5. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Sorry, I keep forgetting to plug in my kill-a-watt. I'll go do that as soon as I finish this post. (edit: KAW plugged in)
    I drove around a lot on the weekend. Lots of little trips but really not much time to charge in between. I put on maybe 100 miles or so? Something like that. My gas mileage was around 70mpg. I only had maybe 4 hours of total charge over the weekend. Thankfully I can still get around 50 mpg without any charge.
    I drove to work today on all EV (Cons MPG 999). I got to work with about 0.6 miles of EV left. I'm being a little harder on the throttle so I think that's where I lost a bit of range (compared to my Friday commute to work which left me with 1.1 miles of EV). I got my car tinted today* so I wasn't able to get any charging before heading home. I figured since I wasn't going to try to maximize my gas mileage, I might as well hammer on it and drive it like a rental :). When I got home, my Cons MPG for the day was 70 and my trip home was 45mpg. Not bad for flooring it off the line (it's actually quite peppy).
    I'll report back tomorrow with a kill-a-watt reading.
    *Funny thing happened at the tint place (Perfect Window Tint in Santa Ana, CA).. When I called to see if I could pick up my car, the owner told me there was a car just like mine getting its windows tinted. He told me the customer kept asking "wow, how did he get it?". When I dropped my car off in the morning, there was a non-plug Prius there as well. It was also winter gray metallic. I figured it was this cars owner who was inquiring about the PiP. When I arrived to pick up my car, it in fact was another Plug-in Prius, same color, but the Advanced model. Turns out we both bought our cars from Dianne, we both have the same color, we both work in similar industries, and we both went to the same college. It was the first PiP I've seen outside of Carson Toyota. As a side note, the tint shop owner told me he tinted the windows of 6 (six) Prii today.
  6. eddiesudz
    eddiesudz Junior Member
    64
    Anaheim Hills, CA
    Hey Tracksyde.... quick question on the tint job. Wanna get mine done in the next week or two. What type of tint did you go with and what shade? (Light, Medium, Dark). Would you recommend Perfect Window Tint?
    Thanks!
  7. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    I haven't yet seen any videos of PiP driving pure EV, so I'm posting two videos, driving aprox. 11.5km one way with pre-production PiP. Enjoy!
  8. samlal
    samlal New Member
    30
    So Cal
    Hi Tracksyde,
    I picked up a winter gray metallic Base model from Dianne this Sunday afternoon. I have a reservation to get it tinted in San Diego this Thurday.
    Since this is the first time I am getting a car tinted. Can you tell me if you tinted the driver and passenger windows also? As per the rules it appears we are not allowed to tint those.
    Can you also provide some information about the type of tint you used and the cost.
    Thanks
  9. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    eddiesudz and samlal, I PM'ed you guys about my tint. Let me know if I can be of further assistance.
  10. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Doesn't Toyota have an iPhone app for the Plug-in Prius that displays charging data in real time?
  11. lensovet
    2,615
    496
    Burlington, NJ
    yes, Entune handles this and it's only available for the advanced model
  12. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Last nights charge was 3.28kWh. I'll post a pic when I get to work.
    EDIT:
    4 people like this.
  13. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    lets see your Pip with tint
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Is that empty to full? How empty? How many battery bars in HV mode?
  15. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I think when I got home last night I had 4-5 bars with 0 EV range left.
    This morning I made it to work today with 1.4 EV miles left.
    However, I was trying to capture some video showing 0-50MPH EV acceleration. On my first try I was a little too aggressive on the throttle and the ICE came on. Reviewing the video, I never got it into the PWR section. However, it was right at the edge for a little bit. I guess thats enough to trigger the ICE. My MPG for the trip was 366.
    I'm uploading to YouTube now but I'll start another thread with just the videos.
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    You would benefit greatly from a plug at work.
  17. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    My impression is that the prototype PiP turns on the gas engine when you still have a mile or so of EV capability left in the battery and then after it finishes its 40+ second warmup it turns back off but is subsequently much more likely to turn on due to acceleration etc. until EV mode is completed when the very last of the battery charge is used.
    Is this still true in the 2012 production PiP?
    If so, it would be great if folks would report both how many miles they get on EV before the gas engine first starts its warmup cycle and then separately the total number of miles until EV switches to HV due to the battery charge becoming completely drained.
  18. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    This is not true of the 2012 production PiP. If I'm trying to stay in EV, the ICE wont come on until my EV range is 0.0 (its actually quite unsettling to watch your EV range diminish to 0.0.. like watching your dog go over a waterfall and you cant do anything about it :D).
    This morning, I triggered the ICE during my 0-50 MPH "blast" but after that mishap, the ICE wasnt more prone to come on. I still made it the rest of the way to work on pure EV.
    3 people like this.
  19. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Thanks for all this info....
  20. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Personally, I have three kinds of trips:
    1. Five miles or less to local stores. My present ICE gulps gas and spews emissions and never quite warms up. PIP - perfect.
    2. 15 miles, half on surface streets and half on freeways, to further stores and appointments. Some ICE use, but PIP should still be pretty good. Or I might hold my speed to 60 instead of 65 (the limit is 55) and do it all on EV.
    3. Occasional 40 - 50 miles round trip, mostly on freeways. Will probably get home with a little EV range still remaining.
    For the last two, I am just as happy to drive hybrid on the freeways, and not lug around any more battery weight than the PIP has. The sweet part for me is that when operated as a hybrid on longer drives, it is just as good as a non-plug-in Prius.
    (Except for the stuff Toyota threw overboard to keep the hybrid mileage at 50 - like the spare tire. :( But life's full of tradeoffs.)
