NAV system map updates
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by desertcrawler, Mar 4, 2012.
  1. desertcrawler
    desertcrawler Junior Member
    Woodside, CA
    So I got the fancy one with the advanced trim. I really like the NAV system, moving over from Garmin I think it is an improvement.
    I was poking around and figured out how to update the maps, it looks like it uses a USB. My maps were last updated in 06/11 -- I guess my NAV unit predates the build date for my car -- I was wondering if anyone knew what the current map versions were/are and what the policy is for getting updates -- does that happen for free or is there a charge? Owners manual is a little vague...
  2. CharlesH
    2,798
    1,166
    Roseville, CA
    The advanced package uses a hard drive rather than a DVD for the map info. I believe that the map updates are downloaded over the USB. And expect to pay big $$$ to get updates (I don't know how many hundred dollars the annual updates are).
  3. ely105
    ely105 New Member
    111
    72
    San Jose, CA
    Garmin usually does annual updates, not sure what Toyota does.
    Anyone update their map data in an earlier Prius? cost?
  4. stacey
    stacey ☆☆☆☆☆
    115
    Lancaster, PA
    I updated my 2006 last summer and the DVD was about $200. It was the first time I updated and I only did it because I was doing a lot of out of state travel and I wanted to be as up to date as possible.
  5. dragonfinder1
    dragonfinder1 Junior Member
    79
    oregon
    I have lifetime map update for my Garmin 660, they say 4 times a year for updates, but I've been getting them about every 60 days or so.
  6. desertcrawler
    Woodside, CA
    Does anyone with the new plug-in 2012 with advanced trim have more recent maps than June of 2011?
  7. plugged-in
    plugged-in Junior Member
    22
    irvine
    No. It's kind of messed up. I mean the car was just built last month, and they loaded outdated maps?!?! I live in a newer neighborhood built 1 year ago, and my address does not exist in the NAV. I hope Toyota gives us some free updates. The dealer did confirm it was via USB but also did not know how much. He thought it maybe free though. Someone from Toyota HQ would need to answer that.
  8. lensovet
    2,615
    496
    Burlington, NJ
    From Toyota's promotional materials, my understanding is that the download happens using your phone. You connect your iPhone via USB, and it uses your phone's connection to download updated map data.
    N.J.PRIUS likes this.
  9. CharlesH
    2,798
    1,166
    Roseville, CA
    Android phones can use Bluetooth instead of USB, can't they?
  10. Kahuna69
    Kahuna69 Junior Member
    43
    Arizona
    I chose the base model simply because I just use my Galaxy Nexus for any navigation.
  11. lensovet
    2,615
    496
    Burlington, NJ
    Both android and iOS can use Bluetooth for audio but I think for communications both require a USB connection. Could be wrong though.
  12. CharlesH
    2,798
    1,166
    Roseville, CA
    On a Droid, I use Bluetooth for everything: the Audio Player, the phone, and the Entune media apps. My understanding with respect to the iPhone is that there are some issues with Apple's implementation of some of the Bluetooth profiles, and Toyota is having to come up with a workaround. Until then, it's the USB cable for the effected features.
  13. etkal
    etkal New Member
    64
    Can you post a link to what specific promotional materials say this?
    Thanks!
  14. moolman
    moolman Member
    142
    In the past, even for HD systems, you paid for the annual update. If you have the 6/11 map you have the latest version because the next version would be out 6/12 and it's 3/12 right now. With the DVD system you just swapped out the DVD, the USB system, you attach the USB and it updates and supposedly the USB thumb drive works once and deletes itself. I'm sure there is a work around but illegal obviously.
  15. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    Mine worked well in the 2010 and does in the PHV now too.
  16. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    My Entune on my iPhone 4S connects to the Entune on the Prius Plug-in just fine over Bluetooth. The first time I ran Info/Apps and I had Entune open on my iPhone, it just automatically connected and started downloading an update. I do see that Toyota's website says that iPhone must connect over USB, but that seems to be out-of-date.
    N.J.PRIUS and lensovet like this.
  17. calbear
    calbear Member
    180
    30
    SF Bay Area
    My base model PiP has full NAV... don't they all?
  18. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I havent been able to connect my iPhone 4S to Entune over bluetooth. It always tells me it was unable to connect. When I use the USB cable, it connects fine. I've also tried using an iPhone 4 to no avail.
    Is your iPhone 4S on iOS 5.1? Both the 4S and 4 I've tried are on 5.0.1.
    Maybe its a difference between base and advanced. I havent seen any software updates over the phone when connected.
  19. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I'm running iOS 5.1 and I have the same problem. I have to plug the phone into the USB port in order to access Entune features.
    I find that that I have to periodically "wakeup" the Entune app on the iPhone. I'll connect my phone and won't get an Internet connection unless I re-launch the Entune app, or select it from pop-up task bar. A minor annoyance.
  20. tomkessler
    tomkessler Junior Member
    28
    Campbell, CA
    Apple fixed a number of bluetooth profile issues in ios 5.1. I used to have significant problems with my iphone 4S dropping it's connection but they all seem to fixed now.
    The only issue I've seen is that very occasionally I need to restart the entune app. This seems to occur when I e.g. start pandora in my driveway when my phone is connected by wifi and then the entune app loses it's brains when it switches to the cellular network as I drive off.
    Older iphones may not have the correct bluetooth profiles as apple did a pretty significant upgrade of it's bluetooh with the iphone 4S so you have to check on a model by model basis.
