black prius, what color should I paint my new touring wheels?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cnschult, Mar 1, 2012.
  1. cnschult
    cnschult Active Member
    772
    97
    Michigan
    title says it all, I picked up a set of touring wheels and am considering running them without the wheel covers. The dark dark dark gray is going to clash with my black gen II, and since I haven't mounted tires I think it would be easy for a shop to paint them and give them a couple coats of clear coat.
    obviously yellow goes well with black but it won't hide brake dust well and it would make my car look like a taxicab. I am considering lavender but want some suggestions from my fellow priuschatters.
  2. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    I think that you should "paint" 'em red... :cheer2:
    But then I've got an obvious bias. :p
    The OEM rims are powder coated. I recommend that you do the same... :rockon:
    That's what I did; base coat, metalflake coat, clear coat.
    Silver accent ring is ScotchBrite finish.
    No problems after 3 years. :D
    An illustration:
  3. Wimble
    Wimble Junior Member
    30
    uk
    Black. Stealth.
  4. cnschult
    772
    97
    Michigan
    i already run black steel wheelies in the winter with the winter tires so I'm looking for something a little different the rest of the year so its not 12 months of black, I appreciate your thoughts though.
  5. MarvinHC
    MarvinHC Junior Member
    49
    Europe
    White would certainly look good, but of course the break dust will be a bit visible... ;)
    Otherwise what about blue? Could look classy with black.
    or orange if you like it a bit flashy?
    or two tone?
  6. PhazonPhobe
    PhazonPhobe His name is Sora
    221
    26
    28
    Fontana, CA
  7. gramps
    gramps Member
    195
    44
    Southeast Texas
