Gen 3 non-JBL spearker upgrade
Discussion in 'Gen 3 Prius Audio and Electronics' started by xs650, May 11, 2011.
  1. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Gen 3 non-JBL door speaker upgrade
    The attached .pdf shows my speaker upgrade using Pioneer speakers, Dynamat Extreme and some extra work to seal the door holes for better sound.
    Edit: 13 May, added some comments about the rear speakers to the .pdf
    myktek, alfa737 and mainemanx like this.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    :thumb: Looks good. Since I am going to have to get into my doors to install my new mirrors, I plan to sound deaden. Looking around for a good alternative to Dynamat at the moment.
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    If you find something good for a reasonable price, let us know. I have heard that RattleTrap is good, also inexpensive, but it gets very mixed reviews. I have no experience with it.
    Dynamat is pricey. I got mine at Amazon, about $120 for 36 sq ft which is way below list price but still outrageous.
  4. ravencr
    ravencr Member
    117
    NC
  5. ravencr
    ravencr Member
    117
    NC
    Hey guys,
    I just purchased the above speakers for my 2010 Prius Non-JBL, and I discovered that the front door speakers look like this:
    And the rears look like this:
    Did I order the wrong speakers for the front? It looks more like a 6x9" speaker than a 6.5" round?
    Chris
  6. brewcrew9
    brewcrew9 Member
    111
    17
    Madison, WI
    2014 Prius Plug-in
    Chris,
    I have probably the same 2011 non JBL, thanks for the Pictures. Did you figure it out yet and get the speakers to work. I might be doing the same project on my 2011 very soon. Did you have to use an adapter ect.?
    Let me know, if you can
    Thanks
    David
  7. ravencr
    ravencr Member
    117
    NC
    Hey David,
    I have JL audio 6x9's heading my way and I'll let you know how it works out.
    Chris
  8. Kupan787
    Kupan787 New Member
    Sacramento, CA
    Just curious how it all went? I am planning on getting some 6x9 for the front of my Prius, and am wondering how the install went. From what I've read, the mounting depth of the factory speakers is rather shallow, so i'm interested in hearing how your install went.
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  10. ravencr
    ravencr Member
    117
    NC
    Hey guys,
    Sorry for the delay. The speakers arrived weeks ago, and I just haven't had a chance to install them. I'm going to do it first thing Saturday morning if you can hold out till then. Sorry,
    Chris
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Sounds good Chris... I got real interested when I saw the specs on the speakers and my need to find ones that match up w/ pioneer HU 22 watts RMS. Only to find out the speakers are discontinued.! Arrggg. There are still some for sell on e-bay and stores. So I am real interested in hearing what you think of them. What kind of power are you going to send to them?
  12. ravencr
    ravencr Member
    117
    NC
    Peter,
    I'll be running just the stock power output from the Rosen Head Unit, which I'm sure isn't much. I already installed the rear door speakers, which were the 6.5's if I remember correctly, and they seem to be working great. It's hard for me to tell the improvement of the rears, because my driver's side rear speaker was blown when I replaced it, so the sound quality now is obviously way better. One thing to note, though, in relation to sound output is that I have the rear speakers at +3-4 when compared to the stock fronts. So, that probably gives some clue as to the sensitivity of them compared to stock. But, it definitely sounds pretty darn good using these settings. I'm looking forward to replacing the fronts and the dash speakers. I'll keep everyone posted. I don't plan to attack the dash speakers this weekend, though, probably just the front door speakers.
    Chris
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I replaced my rears w/ polks and with my HU, they just don't perform. I could get an amp but I bought the HU because of its output and really don't want to buy an amp. Anyway, thanks for working on it!
  14. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    I'll be watching this thread and seeing how things turn out!
  15. tach18k
    tach18k Member
    406
    SoCal Beach Area
    There is anopther thread going on with picture on the speaker upgrade, most have been putting in round speakers using a new mounting bracket, he made his own. If your handy you can make the plate too. 6x9 should be about the same. You have to watch the depth of the speaker and door panel. I will be doing mine soon.
  16. scblair
    scblair Junior Member
    Gibsonia, PA
    I've been planning an audio upgrade as well, especially for the rears. They sound like they're full of mud - hardly anything comes out. I bought it used (2011 non-JBL) so they might be blown. Anyhow regarding sound dampening I've seen many folks on YouTube use a product called U.Seal or Peel n' Seal from Home Depot. It's quite a bit cheaper.
    Thanks for the note on trimming the adapter rings. I'll probably be doing the same.
    I'm thinking about Infinity Reference 6032cf 6.5-Inch speakers in the back but Crutchfield advises against it because of clearance. Has anyone had luck with those or other recommendations? I'm not needing massive bass or audiophile level equipment, just better clarity and quality. I'm using the stock header.
  17. LasVegasaurusRex
    LasVegasaurusRex Active Member
    234
    110
    Las Vegas, NV
    CLD tiles from Sound Deadener Showdown
    spiderman likes this.
