fuel guage off?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by arewethereyet, Mar 8, 2012.
  1. arewethereyet
    arewethereyet Junior Member
    48
    Oregon
    I just picked up a used 2005 Prius and I am a bit worried about fuel economy.
    Tank was full, I have gone 105 miles and now 4 tenths is gone on gauge.
    Car shows 42mpg since last fill.
    Does this seem wrong?
  2. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I think it's too early to tell. The best way to determine mileage is to fill the gas tank until the pump clicks off once and reset the trip odometer. At the next fillip, fill until the pump clicks off, then divide the mileage on your trip odometer by the number of gallons you just put in the tank. With the Gen II Prius you have, the gas tank has a rubber bladder which sometimes doesn't expand fully when you fill the tank, but over the course of a few fill ups, it will average out. Use only regular gas.
    The 42 MPG you're reporting could be your driving style or the weather or the road conditions (mountainous, for example), which could reduce mileage.
  3. fuzzy1
    10,406
  4. cnschult
    cnschult Active Member
    772
    97
    Michigan
    42mpg is not unusual in the winter with a prius if you don't have an engine block heater or have blocked cold air from entering the engine compartment. Short trips are a killer as well, as are heavier stickier winter tires if you are smart enough to use them in the winter. (Prius cannot be 'rocked' out of deep snow like a 'normal' car)
    try to use the same pump every time at the same gas station, only buy gas from gas distributors found on toptiergas.com for cleaner running, longer-lasing more fuel efficient engine. Chevron will give you the best mpg but is not avail nationwide so I have to settle with Shell (still very good) where I live.
  5. uart
    uart Senior Member
    4,220
    1,210
    Australia
    42 MPG sounds ok, though you will be able to improve this with warmer weather and a bit of practice driving a hybrid.
    I assume that your real concern is that 4 pips should be at least 4 gallons, so you're thinking that you might be only getting 105/4 = 26 MPG or less. Don't worry, the pips on the gauge aren't accurate enough to infer that. Just go with the displayed MPG until you can average your true fuel consumption over several tanks full.
  6. arewethereyet
    48
    Oregon
    Yes, I'm concerned that the 4 pips (what does that stand for?) should be about 160 miles or so based on my MPG. Today, I have 5 left, and I've only gone 115 miles so far. I'll see what it's like after a few tanks.
    Yesterday, I checked the tire pressure and it was at 27PSI or so (winter tires). So, I bumped that up to 38PSI all around. So far, seems to have helped with MPG a bit, I'll know more later.
    My drive to work is about 11 miles and includes a 1,000 foot elevation drop. Short drive, so I don't expect much as far as mpg.
