new projector like 194 led bulbs for front parking lights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ucsmfu, Mar 1, 2012.
  1. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    got these yesterday, best 194 led bulbs i've ever owned, around 400 lumens, clean, clear cut, matches the stock leds, super bright :)
    highly recommended, will be posting pics of it from my car soon, after the weekend, as my car is currently is the shop getting a body kit installed.
    they cost around $20 usd for a pair
    you can get them through jdmtoy or ebay
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    So they're directional rather than 360 deg.
    I'm definitely interested in pics. So far, I haven't found a LED bulb that's an acceptable match to the LED headlights. All the ones I've tried are either too blue or too white (although I'm rather critical in this area).
  3. ucsmfu
    1,498
    420
    canada
    i will post pics up soon 32kcolors, getting body kit installed on my car right now, can't wait
    the valenti's truly look very sick on the blizzard pearl Prius :p
  4. ucsmfu
    1,498
    420
    canada
    here's the pics 32colors
  5. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Those are LED headlights? They look rather blue compared to mine.
  6. ucsmfu
    1,498
    420
    canada
    yes my led headlights are factory stock, and it matches the led parking bulbs that i got, perfect match. Looks more whitish in real life than bluish, maybe bluish due to my camera.
  7. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    I have the smd style led & happy with them for now but yours look awesome & seems to be a perfect match:).
  8. ucsmfu
    1,498
    420
    canada
    yeah, thanks :)
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    How is the heat from those bulbs? Keep an eye on the headlight lens for discoloration.
    Has anyone found suitable LED turn signal bulbs?
  10. ucsmfu
    1,498
    420
    canada
    it's pretty cool, i've been monitoring it, those bulbs are awesome.
    the front 2 the yellow side markers, are there bulbs inside that ?
    the stock led turn signal bulbs are pretty bright already, however i noticed the valenti tailights leds are super bright !!!!!!
  11. Cyberous
    Cyberous Junior Member
    47
    Hollister CA
    I like the look of these bulbs so much I went a little crazy with them.
    Terrible for lighting the road, but they look neat.
  12. ducatiduke
    ducatiduke Junior Member
    31
    NYC
    I really want to get LED lamps for my car but I want them to match the headlights i.e. ~4300k temperature. All the ones i can find are 6000k or more. I guess what i really want is a kit that includes all interior and exterior LED replacement lamps that is 4300k. I have been looking for hours and can't find anything.
    Does anyone know if they make them and point me in the right direction?
  13. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    The white balance is not set to capture the true color of the LEDs. If you have a DSLR, micro 4/3 or high end P&S like the G1X or G12 that shoots raw, you can set manually adjust the white balance afterward to best reflect the true color of the LED lights.... just sayin.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  15. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    There's no such thing as stock LED turn signal on the Prius. Even on the stock LED tail lights, the reverse and turn signals are still halogens (making them half-LED).
  16. ucsmfu
    1,498
    420
    canada
    yeah my bad, they're super bright, i thought they were led's but they're just halogens
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Halogens? Anyway, I am still looking for some bright LED turn signal bulbs if anyone can recommend any.
  18. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Thanks for the recommendation OP-
    Just replaced my parking light OEM bulbs yesterday. The LED's match the LED headlight color perfectly. Toyota should do this from the factory on the Fives....
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Your profile reads 2012 Five. Doesn't the 2012 Five already have LED parking lights or does the factory color not match LED headlights?
  20. ny_rob
    1,968
    813
    L.I.- NY
    Nope, even the Five has standard incandescent bulbs for parking lights :(.
    Just so we're all on the same page- the front parking lights have the orange lens and are on the sides (not the front of) the integrated main headlight cluster.
    The front directional signals (grouped with the LED DRL's) are also incandescent bulbs IIRC.
