Actual MPGs - Anyone Filled Up, Calculated?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cycledrum, Mar 9, 2012.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Hopefully none of you have burnt through a tank of gas, but when you reach the awful moment of going to the gas station, inquiring minds would like to know the results :)
    www.fuelly.com has added Prius Plug-in to the list for 'add new vehicle' :)
    If you can post the EV driving ratio, kWh and gallons consumption, please do, thx.
  2. ely105
    ely105 New Member
    111
    72
    San Jose, CA
    I'm looking to fill up in the next day. I have gone 500 miles and have about 100 miles left "in the tank". Right now it's reporting 63 mpg. This has been a mix of my commute and my wifes. My wife does 35 miles mostly freeway(ice) and mine is 9 miles, surface streets (mostly EV).
    It shows about 110+ miles on EV and the rest on HV. Will report actual numbers when i gas up.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Can you post the EV Driving Ratio screen that shows the kWh and Gallon consumption as well?
  4. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Good thread.. very interested in this....
  5. ely105
    ely105 New Member
    111
    72
    San Jose, CA
    Ok here we go. Filled up on the way home. Overall 530 miles on about 8.3 gallons. Almost 64 mpg. Not bad for the first week and a half.
    5 people like this.
  6. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    im very glad to see Pip indicated gas mileage matches calculated numbers at the pump.
    Gen3 Prius has traditionaly overstated indicated consumption numbers
    The price of gas out there is shocking.
  7. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    $4.32 per Gallon. WOW
    Rochester, NY Regular gas at BJ's today was $3.849.
  8. Kupan787
    Kupan787 New Member
    Sacramento, CA
    Hey, Willow Glen, small world! I used to swim club for a year round team at the high school.
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Good job ely105!
    No MPG gage error, nice!
    530.6/8.289 = 64.01 MPG
  10. UCBRUINS
    UCBRUINS Member
    96
    44
    LA
    Just filled up tonight. Drove 500 miles and filled 8 gallons. The computer was accurate at 63. Had about another 55 miles but wanted to get gas on base.
    90% highway miles with charges only on the way to work. Wish I could charge her up at work.
    2 people like this.
  11. fotomoto
    fotomoto Senior Member
    5,634
    3,812
    So. Texas
    Theres no way to account for electrical consumption except do it yourself?
  12. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    Blaine, MN. $3.69 / gallon
  13. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    27.3 kWh/100mi on electricity and 51 MPG on gas. Doing better than EPA figures!
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    The car kept track of it. From that screenshot, it used 33 kWh which is about a gallon equivalent. He went 121 miles with it.
  15. 9G-man
    1,273
    194
    Atlanta, GA
    I'm not sure I'm impressed with the overall gas mileage though.
    If these folks would have gotten 47 mpg in a regular Prius, then it's about a 40% improvement. Pretty good.
    If they would have gotten the 55 mpg I usually get in a normal Prius, then it'sless than a 20% improvement.
    I wish I could drive one for a week. I was hoping a on 75-80 mpg.
  16. iRun26.2
    824
    169
    United States
    It all depends on how often you can charge...
    If you can drive 1/2 of your miles on EV, you get 100MPG.
  17. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Ouch. 3.849/4.32 Our has been rising fast and is now at $3.25 in colorado springs. I was glad I have not had to buy gas in the last 3000+ miles :D
    Good to see real data. Pretty much what is expected given EPA data (11miles-> 22% EV utility factor).
  18. 9G-man
    1,273
    194
    Atlanta, GA
    True, but I think driving technique and the way the EV range is used will be important too.
    Are they driving using their EV range in EV mode then driving in charge sustain HV mode , or using their EV range in charge deplete HV mode.
    I get the impression that many Pip owners are also first time Prius owner.
  19. HillCountryEVer
    HillCountryEVer New Member
    75
    Kerrville, Texas
    To me the key dependency is the average trip distance between charging. The closer you are to 15 miles per trip the better your overall average MPG will be. For us, based on our typical driving habits, I'm hoping for 104 MPG during a generic week. We'll see...but I agree with an earlier comment that it would be great to try one out for a week before buying. Twould be fun!
  20. ely105
    ely105 New Member
    111
    72
    San Jose, CA
    Yep, WG is home sweet home.
