48,000km Canadian Toyota Service worth it ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ucsmfu, Mar 10, 2012.
  1. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    got my car maintained today, I had my own parts etc... this is the big service.
    labor was $123.70
    shop materials $10.78
    tax $18.90
    total $176.38
    just wondering if you guys think its worth it ? or should i go to another shop that can do everything for cheaper ?
    thought I go to Toyota just because the technicians are hybrid certified.
    let me know what you guys think
  2. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Maybe it is me, but with your own parts this service should have been half the cost. Here in the US the first 30k miles of service is free in the first two years.
    My fiancé pays $80US every 5k miles despite my paying less than half of that for my now old '03 Baja. Now that I have a Prius and look at the maintance schedule - I see little reason for a "specialist" in hybrids. Basic car care 101.....
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The factory maintenance schedule is adequate, but the transaxle and brake fluids should both be replaced at least every 60k (preferably 30k) if long-term ownership is your plan.
    Changing the coolant and brake fluids on the Prius requires a bit more knowledge than your typical lube tech. They are most easily done if one has the Techstream scan tool.
    Anyway, I do not see why a well-informed mechanic cannot do the work properly. Unfortunately, you will not find many mechanics who are familiar with the Prius outside of a dealership.
  4. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    may help to know what was included, also shop rate is probably about $100 / hr so the labour does not look to bad
  5. Tideland Prius
    16,623
    I was gonna say, the labour rate doesn't seem too bad either. A full maintenance is closer to Cdn$300 if you don't supply your own parts.
