2010 - Help! Disabling Reverse Beep
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sherryp, May 30, 2009.
  1. BSWEET
    BSWEET New Member
    52
    Suisun City
    I just bought a 2012 PriusIII and talked to dealer service department, was told they would do it for $69.95, talked to salesman who I bouht it from and he got the shop to do it for free. It does take only a few minutes to do.
  2. RaZa
    RaZa Member
    480
    93
    removed
  3. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I was told that the service dept techs are not allowed to change the seat belt warning beep, but right there in the owner's manual it says that is one of the changes they can make, at least with regard to the speed activated seat belt beep. I asked ahead of time that my reverse beep be set to sound only once, but it wasn't done. I didn't notice until the next morning, which was when I put the car in reverse for the first time. I think I can convince the dealership to take care of it at no charge, especially when I show them a couple of plugs they were supposed to install in the frame, but left in the package in the glove box.:rolleyes:
  4. chuckp
    chuckp Junior Member
    26
    Seattle, WA
    The ScanGauge can do both the reverse beep and the seat belt. The codes for it can be found in this forum. I just installed my 2010's scangauge on my new pip and the first thing I did was disable the reverse beep. Ahhhh!
    Chuck
  5. Fore
    Fore Don't look back!
    494
    107
    I have the Ultragauge it's like the Scangauge but smaller and matches the console better. Does anyone know if you can cancel the reverse beep with it? Thanks~
  6. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Got this ELM USB OBD Scanner http://www.amazon.com/gp/product/B005FEGP7I/ref=ox_ya_os_product from Amazon for $18.69 including shipping.
    Tried the JerryLoz program- said "ELM not connected" so that was a no-go.
    Downloaded Putty, set the session as a com port connect via com 3 at 38400 baud. Executed the commands above and all worked well. Only modification from the instructions was AT SH 07C0 is changed to AT SH 7C0 (I took out the zero to the left of the 7).
    Nice thing is you can run Putty with the ELM device plugged in to the laptop only to check the commands prior to lugging the laptop out to the car. If you have a bad command like AT SH 07C0 the ELM responds with a "?"., when the correct command is sent (AT SH 7C0" you get an "OK".
    The whole procedure w/Putty was pretty simple- didn't even take 5 min inside the car. Backing up is less stressful now without that annoying Beep...Beep....Beep...Beep..
    Rob
  7. Hank101
    Hank101 Member
    108
    SC
    can a program such as putty be used to deactivate speed sensor blocked controls on the stereo (phone dial pad, ect..)?
  8. RaZa
    RaZa Member
    480
    93
  9. ny_rob
    1,968
    813
    L.I.- NY
    Once on the Amazon page- hit the link that says "6 New from $10.29" then you'll see all the vendors that sell that product and their shipping charges. I purchased mine from "HDE" at the bottom of the list. The device is $15.65 shipping is $2.99, total is $18.64. I've used HDE before for other products and they've been reliable...
    Rob
  10. RaZa
    RaZa Member
    480
    93
  11. plam0ne
    plam0ne Ninja
    70
    florida
    finally got rid of the beeps. bought the one in amazon, description says that it wont work on windows 7, tried it anyways and had no problems detecting and installing drivers. thanks ron57108!
  12. AceMulder
    AceMulder Junior Member
    Orange County, California
    Tried the Jeryloz program--that does not work--tried Putty and I get to the ">" screen, -- I have the Prius on and the Elm plugged in (got the $15 one on Amazon), but when I put commands in, the cursor just jumps back to the beginning--characters entered remain as though its not sending the commands. I get no "OK" or no "?". I did change the com to 38,400 baud rate in putty. Also tried changing the actual com port baud rate in the computer as well, still same thing. Any ideas as to what's wrong?
  13. ny_rob
    1,968
    813
    L.I.- NY
    What OS are you running?
  14. AceMulder
    I tried Windows 7, 32 bit and 64 bit and XP (I have three laptops) and same issue--I get the ">" in putty but does not seem to be accepting any commands--when I type and enter, the cursor just jumps back to the beginning of the line.
  15. mitomcua
    mitomcua Junior Member
    CA
    Hello,
    Can someone please confirm if this procedure works on the 2012 PriusIII?
    Thanks!
  16. ny_rob
    1,968
    813
    L.I.- NY
    It works on all versions of the 2012 Prius.
    Some can use the Jeryloz program- for others that doesn't work with their ELM unit.
    Some (like me) must use Putty- but once up and running, it's pretty straight forward.
  17. ny_rob
    1,968
    813
    L.I.- NY
    Did you start a "serial" session in putty?
    Do your Putty com port settings match the settings in device manager for your serial communications device?
  18. mitomcua
    CA
    Thanks ny_rob!
  19. mitomcua
    CA
    Thanks for the instructions!
    What's the command to disable the seat belt beep for the driver side using the terminal method?
    Thanks,
    M
  20. AceMulder
    Yes rob--I did--that's exactly what I did. Computer seems to recognize the device, just can't get the device to communicate with da Prius! :confused:
