Gen2 (2004-2009): What repairs did you do after exceeding 100k miles?
Discussion in 'Gen 2 Prius Main Forum' started by Saquibs2004, Mar 15, 2012.
  1. Transaxle
    0 vote(s)
    0.0%
  2. Inverter
    0 vote(s)
    0.0%
  3. Traction Battery
    1 vote(s)
    4.3%
  4. Engine ECU
    0 vote(s)
    0.0%
  5. Hybrid Battery ECU
    0 vote(s)
    0.0%
  6. Electric Steering Gear
    0 vote(s)
    0.0%
  7. MFD
    1 vote(s)
    4.3%
  8. Front Struts &/or Rear Shocks
    3 vote(s)
    13.0%
  9. Other Failure
    5 vote(s)
    21.7%
  10. No Failure
    13 vote(s)
    56.5%
  1. Saquibs2004
    Saquibs2004 New Member
    26
    Piscataway, nj
    2002 Prius
    this is a poll for gen2 (2004-2009) prius:
    What repairs did you do after passing 100k miles? Only vote if you have passed 100k miles. Thanks.
  2. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    Bought it at 110K in 2010, put on 52K miles. Other than regular oil change, air filter, tire, did change 12V battery once at 140K miles, together with spark plugs, Transaxial oil, headlight bulbs, tail lights.
    Struts and shocks are still original. That's about the next thing I might need but not too soon I guess.
    So far, maintenance cost: $1.28/100 mile, which includes all parts and labor.
  3. Prius Pete
    Prius Pete Active Member
    183
    178
    Toronto
    Both oxygen sensors, exhaust coupling.
  4. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    Bought it new, now it has 138,000 miles, and the only repair has been a catalytic converter replacement - covered under warranty. So I have paid $0 to repair this car.
  5. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    I'm still under 90,000 (88xxx I think) on my 2005 but so far I've paid in order of most expensive to least expensive:
    Gas/Tires/Oil changes/air filters (don't track the cost on these)
    12v battery ($165)
    v-ribbed belt 90916-02570 ($23)
    rear wiper insert ($6)
    antenna for looks ($4)
    I'd probably choose "other failure" on the poll since the 12v battery will leave the car unable to start (and has happened to me) until you replace it.
    I replaced the v-ribbed belt proactively.
    Still considering the years I've had it, only $200 in repairs is a good deal. From all I've read on the forums I don't expect to need any major repairs for years to come.
    I might do spark plugs and transaxle fluid at some point after the 100,000 mile mark but I haven't decided when.
  6. jdenenberg
    jdenenberg EE Professor
    3,951
    1,946
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 Prius is now at 220k miles some expensive repairs at:
    • 150k - both main water pumps (a maintenance item)
    • 150k - struts/shocks (also maintenance items ~$1000)
    • 150k - Steering column (unexpected ~$1000)
    • 175k - Replaced Stereo (flaky CD player - Pioneer ~$250)
    • 195k - HV battery (one bad cell - ReInVolt ~$2000)
    • 210k - 12v battery (Optima Yellow Top ~$170)
    JeffD
  7. Saquibs2004
    26
    Piscataway, nj
    2002 Prius
    How come there are only 5 votes?
  8. gone2green
    gone2green grumpier than the grumpiest old man you know ;)
    117
    17
    Mesa AZ
    2015 Prius v wagon
    had to replace the left front wheel bearing assembly and the hybrid coolant inverter pump went out but that was covered under warranty
  9. dhanson865
    851
    188
    TN, USA
    I see 9 votes.
    I didn't vote because I'm still under 100K miles.
  10. tnp
    tnp Junior Member
    San Diego
    My 2007 Prius 132k miles. Just normal oil and filter changes. 12v battery at 120k miles.
  11. jim240
    jim240 Junior Member
    24
    replaced the 12v battery with and optima @ 130K I was nursing the original with water and charging every 6month. Then the body shop killed it leaving the door open or something.
    I've done the plugs, HSD fluid every 60K, HID bulbs(one kept going out)30K Trunk opener turned to bubble gum 100K.
    It seems the parking light all went out with in a few months of each other, Now that's quality control!
    It has 146K on it now.
    Oh and I got 95K out of the original GY Integrities!
  12. cthindi
    cthindi Member
    177
    85
    Connecticut
    I voted no for transaxle as it was result of an accident. Only item replaced which is not mentioned in the maint. guide was serpentine belt at 125K. But even that should be actually a part of 100 or 120K maint items.
    Still original brakes at 185K and still going good.
  13. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Good thread, but I think it would have been more useful if the poll was: what repairs, if any, did you need in the first 100k miles.
    Perhaps that is what was intended, but as this poll is actually worded it appears to be open for people with arbitrarily high mileage to submit repairs that were made at mileage well in excess of 100k miles.
  14. jim240
    24
    I didn't want to just put "The battery and the trunk do-dad"
