Coolant quantities?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lagreca, Mar 14, 2012.
  1. lagreca
    lagreca Junior Member
    San Diego
    I am getting ready to replace my inverter AND engine coolant on my 2006 Prius. Does anyone know what the quantities that each system requires?
    Also, does each system take the same coolant? Or do they each require a different type of coolant?
    Thanks!
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    You'll need 3 gallons, Toyota Super Long Life Coolant, which is dealer only. The inverter loop will require 1 gallon. The engine will take somewhat more than 1 gallon, but it is really hard to get anywhere close to the full amount out, due to the myriad of hoses. I suggest that you NOT drain the coolant storage tank, unless you have a scan tool to run the pump, or the patience to run the pump directly with a 12V battery and a paper clip.
  3. lagreca
    San Diego
    When you say "I suggest that you NOT drain the coolant storage tank", do you mean the storage thank for the inverter or for the radiator?
    Thank you.
  4. jdenenberg
    jdenenberg EE Professor
    3,946
    1,942
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Seilerts means the thermos bottle that stores warm coolant in a Gen2 Prius.
    JeffD
  5. Wilsid
    Wilsid Junior Member
    91
    I got my coolant at napa full strength. Toyota is mixed.
