AM radio volume
Discussion in 'Prius v Audio and Electronics' started by emsprius, Jan 22, 2012.
  1. emsprius
    emsprius New Member
    BayArea
    Hello everyone!
    I bought a new Prius v about 6 weeks ago, and was wondering if anyone else had this issue:
    I can hear my FM radio loud and clear, even when the volume is at about 8. When I switch to AM, I can barely hear anything. It isn't static or anything, but I have to turn the volume to about 30+ to be able to hear it.
    Not sure if I need to get this checked out or if this is normal??
    Thanks!!
  2. rjparker
    10,157
    6,315
    did your dealer screw on the antenna to the satellite stub? fm will work without it, am won't
  3. CLUBGUY
    CLUBGUY Member
    293
    Cincinnati
    Took delivery of our "v" on 3/10....AM volume is somewhat like yours...
    did anyone at your end figure it out...????
  4. Randyneely
    Randyneely Junior Member
    chico
    same thing here....am vol sucks
  5. zebelkhan
    zebelkhan Member in good standing
    165
    Morgan Hill, CA
    AM volume on mine is also very low compared to FM, iPOD, CD, and phone. I wonder if there is an internal adjustment that could be made.
  6. Daren Janes
    Daren Janes Junior Member
    Did anyone find a solution for this? I have the exact same issue. Fairly annoying when switching back and forth.
  7. rjparker
    10,157
    6,315
    Mine was weak until I put on a longer antenna from an earlier 08 Prius. Secondly, my radio will remember the volume settings used last in that mode. I have a Aux In device that requires 55 while the XM is set around 30, both for Highway driving. I also have the automatic sound level adjust on high.
  8. Mac Prius
    Mac Prius Mod Junkie
    213
    San Diego
    In general, AM volume and clarity will be lower and less than FM. I have the sharkfin antenna and while AM volume is lower than FM, I dont have the huge disparity you are reporting.
  9. lapilot
    lapilot Junior Member
    Orange County, Ca.
    2014 Prius Plug-in
    My 2014 PIP radio AM, surges from what sounds like a full loud digital signal to a lower volume and higher pitch. Dealer claims normal as volume changes with speed. Started claim with national.
