Prius v wagon customized / personalized settings
Discussion in 'Prius v Accessories and Modifications' started by runukraine, Oct 31, 2011.
  1. runukraine
    runukraine New Member
    34
    CA
    The manual lists a ton of personalized settings that either you or the dealer can set. Problem is, I can't find in the manual where it describes how to set these personalized settings.
    After bouncing around briefly in these forums, I found that you can set the smart door unlock so that it unlocks all doors instead of just the drivers side.
    It's pretty easy. You just get close to the car and hold lock and unlock down for about 5 seconds on your key fob. After 5 seconds you will hear two beeps. Two beeps means that all the doors unlock now when you use the smart door. Three beeps means only the drivers side door opens.
    One of those simple things that makes life better.
    Anyone know how to set any other personalized settings?
    4 people like this.
  2. rsuplido
    rsuplido New Member
    WV
    Double press on the fob opens all doors as well.
  3. pvogel
    pvogel '05 Five & '12 v
    87
    25
    Santa Clara, CA
    Page 538 or so of the manual shows all the customizable settings, most are settable from the nav system, go to setup>Vehicle Customization>custom settings
    Peter+
    2 people like this.
  4. runukraine
    34
    CA
    Peter,
    Do you have the Premium HDD Navigation on the v Five? Or do you have the Display Audio on the v Three?
    I have a v Three and there is no Vehicle Customization button on my setup screen
    Edit
    So I went to my car and turned it on and hit settings. Vehicle customization button was there. If you have the car turned on completely the vehicle button is there. If you have the battery on just for radio, the button is not there.
    So now I've set headlight shutoff to 0 seconds and set the smart door to open all doors with one touch on the handle.
  5. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    Peter's car is the Advanced Tech one. Your v THREE doesn't have his settings.
  6. jcl410
    jcl410 Junior Member
    Maryland
    OK; Call me dense... Where in the (huge) manual is that described? I couldn't find it! (BTW - I have a trim 3, and am looking for the SKS system to unlock all 4 doors when I grab the driver's handle.)
    Aloha,
    John
  7. runukraine
    34
    CA
    Found it in the forums here relating to another Prius model. Figured I would give it a try and lo and behold it works. Love opening all four doors by just grabbing the handle and not fiddling with the keys!
    Just get close to the door and hold down lock and unlock on the key fob at the same time until you hear the two beeps. From then on, wonderfullness...
    I skimmed the manual, so I can't say it's not there...
  8. pvogel
    87
    25
    Santa Clara, CA
    The guide on page 538 says what page the customization is actually described if I recall correctly.
    Peter+
  9. Prius_zero
    Prius_zero Junior Member
    22
    Louisiana
    Thanks for the tips. Got my four doors unlock mod. It's one thing I miss coming from my 08 prius.
  10. Lngbrdr
    Lngbrdr New Member
    Rocklin, CA
    Actuallly it doesnt. :confused: The Vehicle manual says that you can program certian functions with the NAV System but doesnt explain how. It says to look at the nav manual for programming info. The Nav manual says nothing about how to customize these settings and says for an explanation look in the vehicle manual.:mad:
  11. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    From page 124 of the Nav. System owner's manual:
    Step1 press setup
    Step2 touch Vehicle
    Step3 touch Vehicle customization
    Step4 touch the desired items to be set
    - For a list of the setting that can be changed, refer to Owner's manual.
    Step5 After changing the settings, touch "save". ...
    And here is a link to that section of the Owner's manual. Note the three rightmost narrow columns. Read first page of link to see how the columns show what settings can only be done by the dealer (or ScanGuage if you play with the on-board diagnostics (OBD) toys).
    http://www.toyota.com/t3Portal/document/om/OM47674U/pdf/sec_06-02.pdf
  12. rjparker
    10,170
    6,323
    Smart Key Unlock Option
    Worked for me. Thanks!
  13. nieciez
    nieciez New Member
    Virginia
    Thanks for the tip....I can't wait to change mine...thought I would have to ask the dealer to do it.
  14. Harry Pottar
    Harry Pottar Junior Member
    24
    MA
    Just thought I would chime in here it might be obvious to most but I thought I would state it anyway. The reason only the driver door opens by default is safety. Lets say your wife is parked in a car lot at night, she opens the door she wants to make sure the others doors don't open as well. Call me paranoid but I like that safety feature stops some one rushing the car and getting in the other side.
    It only takes two quick clicks of the remote to open all the doors if you out with family and friends.
    Just my 2 cents
    paranoid
  15. blane
    blane Carmudgeon
    98
    56
    NJ Suburb of NYC
    2019 Prius
    I was searching for the same solution for my regular 2011 Prius (non-v). It worked like a charm. Thank you if you are still following this thread.
  16. joeruo
    joeruo Junior Member
    25
    boston ma
    Son of a gun, it worked. Thanks for the tip
  17. joeruo
    25
    boston ma
    Thanks for that tip. I didnt think i had that option
  18. owayneo
    owayneo Junior Member
    This blog has been so helpful in so many ways. Thanks for the locks trick. Thought it was only possible in the V5.
    Wayne
  19. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    rjparker and joeruo look like they have prius v (wagon) 3s and posted that they got the procedure to work. See their posts above.
