Changed my oil and MPG went from 53 down to 46. Wth??
Discussion in 'Gen 2 Prius Fuel Economy' started by mike52474, Feb 26, 2012.
  1. mike52474
    mike52474 New Member
    29
    bellbrook,oh
    actually I have a great feeling that me resetting my odometers and my mpg returning to normal were nothing but a coincidence and that I just had not given it a chance to come back to "normal" yet. Scary thing is this was a manager in the service dept. in a toyota dealership that told me this would fix the problem??????
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    534
    Tucson, AZ
    2021 Prius
    In a related mpg issue, I recently replaced my 12V aux with the Optima YT after watching my mpg steadily decrease from 50+ to 47, then to 42. There was an initial improvement back to 47, but then it decreased into the 45-46 range. After reading the OP I reset both trip odo, and sure enough after a few days my mpg is back up in the 48-52 range. Odd.
  3. bugly64
    bugly64 Junior Member
    66
    Marysville, CA
    I have noticed a 48.6 to 43.5 drop in my mpg's since my servicing. The trip odometer, that I didn't know I had, had not been reset 70k plus miles and 58k plus respectfully. The dip stick is over also. I reset the trip odo's and will get the oil level down tomorrow.
  4. uart
    uart Senior Member
    4,220
    1,210
    Australia
    How far above the top mark is it bugly? My dealer used to consistently overfill about 1/4", unfortunately it's very common. When the overfill get up around 1/2" it's starting to be a real cause for concern.
  5. bugly64
    66
    Marysville, CA
    It's 1/4" over.
  6. richard schumacher
    7,664
    1,046
    United States
    Next time use three quarts exactly and avoid any question. You can always top it off later if it makes you feel better.
