What's Your Longest EV-Only trip?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iRun26.2, Mar 18, 2012.
  1. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    Just for fun, I like to go cruising around in EV-mode. The other day, I decided to see how far I could extend my trip by driving (safely) at slow speeds and 'gliding'. This is what I ended up with: 17.3 miles (999mpg)
    Not making this into a contest, but what have other people achieved (without helpful hills...that is)?
  2. k9frog
    k9frog New Member
    88
    sullivan co ny
    Ok im impressed !!!
  3. bisco
    51,820
    well done! what was your avg. speed?
  4. LenP
    LenP Member
    257
    69
    Morris County, NJ
    Shhhhhhhhhhh don't tell the EPA :D
  5. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
  6. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    Maybe 17.3miles/(54mins/60mins/hr)= 19.2 mph ?
    That was some slow cruising.
    I assume start point = finish point ?
  7. gwmort
    gwmort Active Member
    985
    211
    Delaware
    So far my record is 48.7 miles, hoping to break the 50 mile barrier this summer.
  8. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Well I did not want to hijack this, but I'll follow on after gwmort.
    It is very easy to exceed EPA in EV mode. Much more variation than in an ICE.
    Well my minmal elevation change record is 62 (1.7* EPA) (mostly 30-35mph). With some mountain downhills I've gone well over 2x EPA and mostly at highway speed. Next summer.. I'm going for 100!
    I break 50 regularly; best at winter temps was 51.6 returning home at 30F.
    Great job iRun26.2, maximizing EV and MPG is very addictive. Soon you may develop gas anxiety, a bit like range anxiety for an EV, but you'll be worrying about the ICE starting rather than being stranded.
  9. iRun26.2
    824
    169
    United States
    I have to admit, I had kind of forgotten about you (Volt) guys. While, for comparison purposes, it is nice to hear the numbers that the Volt is getting, I am hoping to also hear from other Plug-in Prius drivers.
    I do not want to have started yet another PiP vs Volt debate thread!
    3 people like this.
  10. iRun26.2
    824
    169
    United States
    Yes. Start point = End point = My garage
    (Also, there were quite a lot of stop lights and stop signs on my trip)
  11. LenP
    LenP Member
    257
    69
    Morris County, NJ
    I got close to 15, but I just did normal driving, 35 to 40 mph roads mostly flat terrain.My poor ICE is going to rust if I don't use it more.:) My gas tank is still on full after a week of driving...YES :D
    2 people like this.
  12. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    Well, if you Volt guys can jump in than I guess I can jump in and say that I've done over 70 miles in my Leaf before, with range left to spare.
    Seriously, though.. I will be following this thread. I'm curious if anyone will be able to make it 20 miles or more in a PiP.
    Drake and HillCountryEVer like this.
  13. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    300+ miles from London to Paris at speeds ranging from 99-186mph.:rockon: Took about 2.5 hours and I drank wine the whole time!:eek:
  14. iRun26.2
    824
    169
    United States
    My 17.3 mile EV trip was at night, so my headlights were on, wasting addition charge. :rolleyes:
  15. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    The best I've managed so far was 14.3 or 14.4. It was a regular morning commute. However instead of turning into the parking lot, I figured I'd drive around the block to see when it would run out.
  16. drinnovation
    2,027
    586
    65
    CO
    Not very impressive, that's below the EPA estimate. The Op's 17.3 miles was 57% above the EPA estimate. Leafers need to hit 114 to be doing at least as well. Its not how big your is, its what you do with it. :D
  17. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    ""To summarize, the Volt and the plug-in Prius cost about the same, but with the Volt, you're getting what in our opinion is a substantially better car. It's got more battery life, it's faster, it's more powerful, it's better looking, and it's much more fun to drive."
    To be fair, a base PiP costs less than a Volt, even given the lesser tax credit allowance but you do get a lot less battery range, a significant selling point.
  18. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I agree. you shouldn't count how many miles but how many percent above the EPA rating.
  19. LenP
    LenP Member
    257
    69
    Morris County, NJ
    Thank you very much. First of all the base PIP cost $32,000 the Volt costs $45,000 here in NJ,thanks to the greed of the GM dealerships. So $13,000 is not even close to being the same cost. I've owned GM Chrysler and Ford, and no way is their quality anywhere up to Toyota's. I'm sure the Volt is a very nice car, but all this GM bravado is something to post on the Volt web site.This isn't about who has the best toy it's about learning about the PIP from others.
  20. kkitzhaber
    kkitzhaber Member
    Owen, WI
    Just went for a cruise in my new PIP, just to test the EV range. I went out and back, and got 15.6 miles. Relatively flat, and no traffic. However. it was 12 degrees F.
