Hybrids with All Wheel Drive?
Discussion in 'Other Cars' started by cycledrum, Mar 19, 2012.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    It looks as though the lowest price hybrid with AWD or 4WD is the Ford Escape hybrid. Not cheap, $33k new.
    My sister was here a couple weeks ago and was getting to like my Prius. They live in snow country and like to go up skiing and depend on 4WD (AWD would be fine). She asked if there are AWD hybrids. Best answer I could give is the Escape. HiHy and RX400h are really expensive and they don't like expensive cars.
    Would be nice if Toyota could make an AWD version of Prius v for all those folks in slippery snow areas. Apparently the Lexus just uses electric motors to power the rear wheels. No need to run mechanical drive line to rear.
    Did I miss something?
  2. hill
    8,800
    Our Lexus RX-400h is awd ... if you call it that. The rear wheels have no connection to the fwd. Iow, the rear wheels are just driven by the rear electric motor. It only provides power at low speeds or when you demand harder acceleration. But like you say ... they aint cheep. It's cousin the hyhi also comes in awd, configured in the same manner. EPA's around 30mpg.
  3. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Toyota Highlander Hybrid, tow capacity, third row, AWD. It's $38k or something.
    The thing is realistically AWD in modern vehicles is a waste of weight and money for virtually everybody. I've had AWD vehicles before and they are nice in the middle of a snow storm, otherwise you're just carting around that extra drivetrain mass (and its price) when you don't need to be. This must be a bit of a squeeze point for Subaru which has AWD in everything. Its base imprezza is $19k. Compare to a similarly equipped but-no-AWD competitor, it's a couple thousand bucks more.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    When I lived where it snowed 10 months of the year, a Subaru Forester made a great deal of sense. Now that I live in Mississippi, I drive a Prius.
  5. R-P
    R-P Active Member
    804
    288
    Netherlands
    Model X? :D
    Can't think of any cars that would fit the bill, and apart from the RX400/450h I can't even THINK of any that are on the market here (including the ones you mentioned: not sold here I think...)
    There's a Peugeot coming, but they aim more for the European market, as they are diesel-hybrids.
    I wouldn't mind one to replace my Volvo V70 AWD...
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    They live near Boulder CO and like to go up skiing. They don't take their Camry up their but instead a 4WD Tacoma which drinks plenty of gas. Maybe a Subaru Outback would be the best alternative. Saw a lot Subies while there.
    btw, the AWD HiHy costs almost as much as the RX AWD hybrid.
  7. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    As I have said in these Droups several times, I WANT AN AWD PRIUS! We will need to get a new car sooner or later and the ONLY AWD car that gets about 30 MPG at a reasonable cost is a Subaru (We have a 1996 Outback and it is great). Putting the HiHy rear drive in a Prius would add about $2-3k (my estimate) to the price, retain about the same MPG, improve acceleration, and would get us as a repeat Toyota customer.
    JeffD
  8. RichardAK
    RichardAK Member
    121
    Fairbanks, AK
    If they came out with one, that would be great. I started out looking for an AWD Escape but the cost new or used was exorbitant for what you got and used Highlander Hybrids were even higher. We ended up picking up a Prius v3 and we figured that if not having AWD ended up being a real problem then we would just sell the Prius and get something else. It's an experiment...
  9. SynEco@eVehicle.co.nz
    139
    Toyota Estima Hybrid has AWD
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If they make a Lexus version of the v, it would make sense for it to be AWD.
  11. SynEco@eVehicle.co.nz
    139
    Is called the LEXUS RX450h :) ...
