getting an extra level 1 portable charger
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ernda, Feb 26, 2012.
  1. ernda
    ernda New Member
    43
    Beverly Hills, CA
    I'd like an extra portable level 1 charger to keep at home and keep the Toyota-supplied one with me in the car (in case I need to park next to your house and plug into one of your outdoor outlets:D). Anyway, I only see the Leviton one for sale through Amazon or Home Depot for around $900. Are there any other choices available (especially online)? Legrand makes a big deal about their portable charger that cost $500 but I don't see it for actual sale anywhere. Might Toyota Parts sell them?
  2. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Toyota will sell the same Level 1 charger that comes with the car but I have not seen a price yet. All I have heard is, it's not cheap! lol
    The ones you are seeing online for ~$900, are those level 2 or 1's? If you have a garage, why not get a level 2 installed in there and then you can use the one that comes with the car elsewhere... That's pretty much how I'm going to use mine. The one which comes with the car will never really be used at home, I'll just solely use the Level 2 I had installed for at home.
  3. ernda
    ernda New Member
    43
    Beverly Hills, CA
    most of my garage is, let us say, "occupied" right now and there is no real place to put a level 2 charger at this point. I'd rather have the flexibility. The $900 is for a level 1 portable charger.
  4. Batteries_Included
    Batteries_Included New Member
    Walnut Creek, CA
    Toyta dealers quote $1200 for a spare level 1 charger (this is with an employee discount)
  5. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    :eek: That's insane.
  6. CharlesH
    2,787
    1,153
    Roseville, CA
    Talk about a markup, for an EVSE, cord, and J1772 plug!
  7. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    I'm looking at the evseupgrade.com new unit for $979 + $48 Upgrade (for full 16A) + $20 shipping + $25 120v adapter.
    This unit will work on 120v or 240v.
    When looking at cheaper units, look at what current they will run at. Make sure it will go up to 16 amps.
  8. in-control
    in-control Junior Member
    32
    Charlton, MA
    Give it a year and they will be available for a couple of hundred $.
  9. LenP
    LenP Member
    257
    69
    Morris County, NJ
    Home Depot and Menards both sell Legrand.
  10. LenP
    LenP Member
    257
    69
    Morris County, NJ
    Mark I'm taking your good example and doing the same thing, but my level2 charger will be outside on my driveway fence, the same way my level1 is for now. After the new unit gets installed the one that came with the PIP will go in the car. :)
  11. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    Or as i've stated on the other thread, build your own 120/240 capable 30A max EVSE for under $500, using the OpenEVSE google project. You can get the control board assembled for $100, then you need a 30A DPST relay ($11 at Digikey), a $30 12VDC 90-270VAC PS, a case, some 10AWG wiring & power cord/L6-30p plug (about $30), and the most expensive part, the J-1772 male end w/20' of cable attached ($261 from Avnet)
    The EVSE you build will be capable of 120V or 240V, up to 30Amps, it will last through the next generation of EVs with 6.6KW onboard chargers... Money well spent.
  12. I922sParkCir
    I922sParkCir Junior Member
    31
    Orange County, CA
    Give it a year and they'll be available from MonoPrice (or some other inexpensive distributor) for under a hundred.
  13. mitch672
    1,077
    197
    Randolph, MA
    Don't expect EVSE prices to drop until EVs and PHEVs are selling in the hundreds of thousands, there simply isn't enough volume to get the manufacturing cost of the single most expensive part down in price, and that's the J-1772 cable and connector, the rest is peanuts.
  14. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    It might be worth checking with a Nissan dealer parts department or two to see if you can order the LEAF 120v charge cord. They may be cheaper and more available than the Toyota one since the LEAF has already been out for over a year.
    The LEAF cord is made by Panasonic and seems be well-built. The only trick is that in these early days there may be slightly different interpretations of the J1772 spec. While almost all charge cords and cars work together there have been a few interoperability problems. In particular, the early LEAF cords did not work with the Volt although the Volt cord works with the LEAF. This may have already been fixed with newer LEAF cords but it's worth researching its compatibility with the PiP first.
  15. ddunlea
    ddunlea Junior Member
    22
    Columbus, OH
  16. mitch672
    1,077
    197
    Randolph, MA
    Yes, but for a little more you can get a Nissan EVSE, and get it upgraded to handle 240V @ 16A, so you could charge in 1.5 hours.. It will work on 120V or 240V, with different AC adapter cables.
    see this site:
    EVSE Upgrade - Products
  17. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
  18. mmstuart
    mmstuart New Member
    53
    30
    The Chevy Volt 120v charger was recalled on March 15 and is short supply. I would hold off getting a Volt cable until someone can determine what the part number of the new charger it.
  19. mmstuart
    mmstuart New Member
    53
    30
    It seems there have been three versions of the cable so far 22781210 (recalled), 22809287 (unknown), and now 22865050.
    The link above to ShopChevy goes to cable 22865050.
    I am guessing if you order one make sure you get the latest version.
    New designed 110volt charger just released
    2 people like this.
  20. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    From EVSEUpgrade.com, they have this FAQ on their front page:
    So, if the old units were heating up, is it possible the wiring was upgraded on the newer Volt EVSEs to 12 gauge versus the old 16 gauge?
