Dome light short: no smart key or int lights...
Discussion in 'Gen 2 Prius Technical Discussion' started by navguy12, Mar 20, 2012.
  1. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    Help!!
    Putting in an LED into the dome light (over the back seat area) and my smart key system as well as my interior lights do not work.
    I couldn't even turn on my head-lamps until I put smart key into dash-board and now I get head-lamps when manually turned on.
    The fuse for the smart key is good and the other items on that fuse all work. Can't sort out what fuse would tie the smart key system to the interior lamp system, but those 2 systems are not working.
    I undid the negative wire from the 12 volt battery in an attempt to 're-boot' the car, but still no luck.
    I'm about to go on a test drive to see if I can actually drive the car....
    Again, I think I may have created a momentary short across the leads for the ceiling light bulb in the dome light as I was trying to install an LED with a festoon bulb adapter.....
    Thanks
    Cheers
    Mike
  2. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    After my test drive, the "VSC" warning lamp is glowing on the dash-board....so no smart key, no stereo system, no interior lights and no VSC.......
    ....please pipe in if you think you know what it would be.......
    Thanks
    Cheers
    Mike
  3. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    no clock...must use mechanical key to lock or unlock doors....
    ...have I fried my "Body ECU"?
    I ask because looking at my Bentley's manual, all these items tie together at the "Body ECU".
    Scan Guage II does work, I get my 'numbers' on my test drive....and it says 'no codes' and 'no pending codes'.
    Help....:(
  4. koolingit
    koolingit Member
    158
    52
    Mocksville NC, USA
    Dome lamp fuse in engine compartment fuse box?
  5. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    I checked EVERY single fuse in this car. No fuses are blown.
    • no auto-dimming mirror
    • no Home-Link
    • no Smart Key
    • no interior lights
    • no exterior lights or headlights unless key fob in slot and power button pushed on
    • no power locks via power lock button unless key fob in slot and power button pushed on
    • no access thru rear hatch unless key fob in slot and power button pushed on
    • no clock
    • no stereo
    • VSC warning when car is driven
    • hybrid system works, AC works, electric steering works, multi-disply works
    :eek:
  6. Patrick Wong
    18,210
    6,514
    It is hard to believe that some fuses are not out, given so many systems are not working. I hope that you used an ohmmeter to verify each fuse is good - do not rely upon visual inspection. Also note that the car has a fuse box under the dashboard as well as the main relay/fuse box near the inverter.
    If you still do not find a fuse problem, then I suggest that you obtain the electrical wiring diagram for your car from techinfo.toyota.com
    Then start with a simple system like interior lights or the clock, and work from that system backwards towards the 12V battery until you find where 12V power is available. That will be the point where that particular problem resides. Good luck.
  7. qbee42
    3,081
    This is a fuse problem, regardless of the OP's comments to the contrary. Clear the short, if it still exists, and replace the bad fuse or fuses.
  8. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    100% correct. I rechecked the fuse I logically thought it should be, the 15 amp 'dome' with an ohmmeter and sure enough, it was blown......
    Thanks folks, new fuse in and all is well in my world again :)
  9. PriusFUN
    PriusFUN New Member
    minnesota
    Can someone show me where to locate this fuse? I did the same thing!
  10. bisco
    52,398
    it should be in the fuse box under the hood, by the steering wheel. i believe the o/m shows it.
  11. PriusFUN
    PriusFUN New Member
    minnesota
    Got it, thank you
  12. Knightrider
    Knightrider Member
    149
    36
    Kansas
    Still fighting this exact issue on my car
    Started getting failed combo unit
    Updated to 06 w updated layout and mileage to go beyond 300000
    I am beginning to wonder if I have a wire between underhood fuse block to interior junction @ the drivers footwell
    I have no dome radio/audio vsc lamp is on no lamp on at the key slot no smart key functions
    Mfd displays no audio
  13. William Hutchinson
    William Hutchinson Junior Member
    New Hampshire
    Three Touring
    I have the same issue except my dome light fuse keeps blowing. What could be causing that?
  14. PNWbluegen2
    PNWbluegen2 New Member
    Seattle
    Any luck with a resolution? I have the same problem.
