IG-ON
Discussion in 'Gen 2 Prius Main Forum' started by Howard, Dec 14, 2005.
  1. Howard
    Howard New Member
    72
    Valencia, California
    I am looking at the Prius manual and I keep on seeing the abbreviation "IG-ON"
    I know I must have over looked what this means, so I would appreciate it if someone can explain this to me.
    Thank you.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Just like any other car you've driven really. There's ACC (accessory) mode with gives electrical power to only a limited number of things...radio, windows, etc...but no fans, etc.
    IG-ON gives you electrical power to almost everything but doesn't actually power up into READY mode.
  3. jamarimutt
    jamarimutt New Member
    985
    In is engaged by pressing the power button without touching the brake pedal.
  4. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Stands for IGnition-ON. It is equivalent to what you would have in a conventional car if you put it to ON, but not start it.
