Shocking Car
Discussion in 'Gen 3 Prius Main Forum' started by mrb1, Mar 20, 2012.
  1. mrb1
    mrb1 Junior Member
    17
    Earth
    Every time I get out on the driver side and close the door I get a big shock. It's strong enough to make me scared to touch the door. Now I close the door by pushing on the window. Anyone else experienced this or know how to fix it?
  2. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Do you live in an arid region on Earth? Do you have fabric (cloth) seats? If you answered yes to both then it is most likely static electricity. Get some Bounce fabric softener sheets and wipe your seats down with them. That should solve any static electricity problem.
  3. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Those hybrid cars all do that. If you want safe and reliable transportation, get a horse.
  4. TruSound
    TruSound Member
    246
    32
    The 818
    Mine zaps the heck out of me every time...I'll try the bounce trick.
  5. RaZa
    RaZa Member
    480
    93
    removed
  6. qbee42
    3,080
    As per the first reply, it's static. I have commercial anti-static spray that we use in the electronics industry that works well. You can also use Cling Free or fabric softener sheets to treat the seats.
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    My girlfriend's Rav4 does that all time. I think it is telling me it need oil. That thing chugs oil!
  8. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    My Honda CR-V (with cloth seats) is notorious for shocks. As a matter of fact- my wife just mentioned shocks to me yesterday now that the CR-V is her daily driver. Her Expedition w/leather seats never shocked her.
    Solution- keep your hand on the metal door frame (or any other steel part of the frame) as you slide off the seat and exit the vehicle. It takes a bit of training- but that solved the problem for me....
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    +1 Agree
  10. movingforward
    movingforward Member
    169
    The Great White North
    I am numb to the shocks now, does't bother me anymore. Usually only happens in the winter for some reason...
  11. AZGeek
    627
    144
    63
    Arizona
    It is attributable to the Lower relative humidities during the winter. Low relative humidity means less ions in the air to pick up or attract the charge generated from the transfer of electrons that results from two surfaces rubbing together. Synthetic fibers are good generators of static electricity because they have more electrons to exchange. When the humidity is low there aren't as many ions in the air to accept some of the charge that you have collected. Hence more zaps in the drier winter months.
    Cool science trick: pick up a nice static charge and touch a grounded compact fluorescent bulb. You can get the bulb to briefly light up.
    Yep, ima geek. :D
    2 people like this.
  12. Slugdoc
    Slugdoc New Member
    Bronx, NY
    Yup.
    I bought my prius in the winter (if you can call it that in the NE this year)
    and was definitley more shocked than in my Saturn.
  13. macman408
    1,179
    368
    I think it can be affected by the type of tires the car has, too. My parents got new tires for their old Honda Accord many years ago, and the shocks got worse. According to Car Talk, LRR tires can be worse for this - the stuff they use to reduce the rolling resistance also has the side effect of increasing the electrical resistance.
    Another thing you can do, if you forget to hold on to metal the whole time you're sliding off the seat, is to use your fingernail to discharge the static; I'm not sure if it has higher resistance than skin (hmm, DMM sitting next to me says yes), or maybe it's because there are fewer nerves there, or possibly because the nerves are further from where the electricity (and heat and spark) are concentrated - separated by a layer of dead nail. Moral of the story, though: it's not uncomfortable to discharge static through your fingernail.
  14. mrb1
    mrb1 Junior Member
    17
    Earth
    That Bounce sheet really works good! Now I don't have to leave finger prints on the window. Thanks AZGeek!
  15. AZGeek
    627
    144
    63
    Arizona
    :thumb: No problem, mrb1.
