ScanGauge For the Plug-In
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jbrad4, Mar 5, 2012.
  1. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    A question I saw elsewhere: Will the ScanGauge II work with the Plug-In Prius? The answer is "Yes".
    The ScanGauge II now lets you add specific codes for the Prius under what are called Xgauges. I don't want to repeat others good work on this, so just search PriusChat for "Xgauge". A lot of the Xgauges for the Prius are listed here on the ScanGauge site. The Xgauges for the Gen III Prius should work with the Plug-In. I believe this is the Main Thread for ScanGauge here on PriusChat.
    When you set up the ScanGauge II, Under MORE> SETUP> FUEL TYPE (options are Gas, Hybrid, Diesel A or Diesel B> SAVE. Select Hybrid or else your ScanGauge will shut down when your Prius goes into Battery Mode (when the ICE shuts down).
    4 people like this.
  2. pfile
    pfile Member
    319
    35
    bay area, ca
    i just tried entering a bunch of codes from the google document. BV+ (total pack voltage) does not seem to work. does anyone have any updates for the PIP?
  3. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi pfile,
    Is your SGII Firmware 4.04+ ?
    If yes, it is likely that this PID is changed in PiP. Could you test if this works:
    XGauge TXD RXF RXD MTH NAM Notes
    1 Battery Voltage (Pack) 07E22174 010702EA0321 2810 000100020000 BV+ xxx V
    Alternatively, you can also tried this VB that works in Torque:
    1 Power Resource VB 07E22181 010702EA0323 1810 0001000A0000 VB xxx V
    Vincent
  4. pfile
    pfile Member
    319
    35
    bay area, ca
    unfortunately the SGII has downrev firmware, 3.xx. can't remember exactly. but i will try that code and see what happens.
    i'm going to send the SGII in next week to be upgraded.
  5. jbrad4
    474
    148
    Rowlett, TX
    I just got my ScanGauge II back from Linear Logic after having it upgraded. I haven't had a chance to try it out yet. I pick up my PiP in 8 days. There was less than 7 day turn-around on the upgrade.
  6. pfile
    pfile Member
    319
    35
    bay area, ca
    bogus, neither of those codes worked. oh well, maybe i'll have some luck after i upgrade the SGII.
    thanks for the info jbrad4 - i really should have done this before the car arrived... the SGII has been sitting since i sold my '06 to buy the leaf.
  7. pfile
    pfile Member
    319
    35
    bay area, ca
    okay, the first code given works with scangauge2 v4.06. thanks very much.
  8. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Anyone else have the problem of it not shutting off ?
    It turns on when the charging begins via the timer, then stays on afterward.
  9. H2OSkier
    H2OSkier Member
    276
    Good question I'm never awake when mine is charging. I can say its off when I get in first thing in the morning.
  10. tomkessler
    tomkessler Junior Member
    28
    Campbell, CA
    While we're at it, does anyone have a photo of how they've mounted their Scangauge II.
    Right now I have it flopping around but I want to do something better with the velcro
    and getting the cable to run so that I don't keep kicking it.
  11. john1701a
    12,817
    5,303
    58
  12. john1701a
    12,817
    5,303
    58
    oops, duplicate
  13. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    I think I'm going to go data free for awhile with my new PiP, and leave the ScanGauge in the 09 Prius. The data that help me the most are the water temp, RPM and IGN. I sometimes cycle through to VLT to read the 12V - that data helped me decide I needed a new one. I've never used the SOC function, so I may not know what I'm missing - it feels like that might be something that I don't think about with my current Prius that I might want to know more about with the PiP.
  14. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    Here is the way I mount my two ScanGauges right in front of the steering wheel. Right below the SOC is the traction battery temperature. Both of these are xGauges. I find it very interesting to watch the traction battery temperature. This seems not to be the issue we have discussed. I have never seen temperatures above 71 degrees, yet.
    The thing on top is a shield to keep the light from reflecting off the windshield.
    The top unit seems to have some problems. I am working on that with Ron DeLong of Linear Logic.
      File size:
      27 KB
      763
    Dudley1030 likes this.
  15. pfile
    pfile Member
    319
    35
    bay area, ca
    i did not know you could daisy-chain them, that's pretty cool. i guess there *is* another RJ45 on there... but i didn't realize what it was for.
  16. H2OSkier
    H2OSkier Member
    276
    This is how I decided to mount my ScanGauge. I used a Blendmount to mount the gauge to my mirror. I removed the cover on the A pillar then tucked the cable from the gauge under the head liner and then tie wrapped the cable to existing wires in the A pillar. It took a couple of tries but it was rather easy to fish the cable down the existing hole towards the ODBC connector. Lastly I coupled the extension cable to the wire with the ODBC end via the provide coupler. Made a nice loop of cable and tie wrapped it all out of the way under the dash. Taking my time it was easily done in under an hour. I could probably do it again in under 30 minutes.
    Ken
  17. pfile
    pfile Member
    319
    35
    bay area, ca
    by the way, for those of you that only have a single scangauge, what are you displaying? as for me, i've got:
    rpm
    fuel flow - to see if the engine is just spinning or actually burning fuel
    soc
    hv battery current
    sometimes i see the fuel flow meter showing 0.02 even when RPM is 0, though.
  18. krishkal
    krishkal New Member
    Fremont, CA
    Sorry about the naive question, but what does the ScanGuage get you that the Prius displays themselves does not? I understand RPM (not sure I am so interested in seeing the RPM myself), but how else does it help maintain/understand the PiP operation?
  19. pfile
    pfile Member
    319
    35
    bay area, ca
    it can show you all kinds of stuff related to the engine and hybrid system: temperatures, voltages, ignition timing. you can also use it to scan for OBDII error codes.
    whether or not it helps you depends on how bad your OCD is :)
  20. CharlesH
    2,796
    1,163
    Roseville, CA
    Doesn't it also have the ability to change all sorts of low-level parameters that could severely adversely effect various systems on the car, or even damage them, if you don't know what you are doing?
