HV Battery (Replacement?) Advice Needed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by climateguy, Feb 16, 2012.
  1. climateguy
    climateguy Junior Member
    65
    Santa Fe, NM
    Hi all,
    I'm looking for some advice regarding my 2006 Prius with 130k miles. I'm thinking that my HV battery has slowly deteriorated to the point where it's causing drivability issues, and now needs to be replaced, but I have some questions. Sorry for the long post...I'll divide it into sections.
    Symptoms
    The main symptoms I'm experiencing are rapid charge/discharge according to the MFD and significant loss of power once the battery has discharged to one bar. I realize the latter is "normal," but the problem is that I'm seeing one bar frequently now. Hill climbs that my car used to do with no problem and would drain the SOC to 2-3 bars now cause the battery to drain to 1 bar about half-way up and then loss of speed from 65 mph to 45 mph by the time I reach the top. Descending hills, it's not unusual to see the SOC go from 2 bars to 7-8 bars within 30 seconds or so.
    I'm not seeing any error lights, and my (cheap) code reader does not report any logged DTCs.
    History
    This seems to be a slow degradation of battery performance, rather than an outright failure. I first noticed that the battery would charge/discharge a little quicker than it had been at about 90k miles. At 99k (before the warranty ended) I took it into the dealer and they tested the HV battery. Block voltages ranged from 16.59 to 16.68 V and resistances ranged from 0.025 to 0.026 ohms. Based on this, they said that the battery was fine, and sent me on my way. Since then, the problem has just gotten worse and worse, though.
    Questions
    My thinking is that I need to get a whole "new" battery - this doesn't seem like an individual bad block (at least based on the readings from 32k miles ago), and I'm not sure I'd be comfortable replacing individual blocks anyway. Do the experts out there concur?
    Does swapping out batteries require anything special in terms of tools? Is there any reason the battery ECU needs to be reset or anything like that?
    Is it better to get a salvaged battery or a reconditioned/remanufactured battery? I've been looking on eBay and, for example, there's a 2009 battery with 34k miles for $700, whereas remanufactured seem to run $1200-1600.
    Are these reasonable prices? Is there anyplace else I should check other than eBay?
    Thanks for any help!
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    If you have a bad or weak battery your mpg should have decreased. Have you noticed any decrease? If the traction battery is weak, the engine should be running much more frequently.
    Most of us obsessed with mpg keep a log. I have had one on Excel for the past seven years for two different cars. I know precisely when my mpg isn't what it should be. So far, my 05 Prius with 165K miles has not varied in the least from month to month in the past year and a half. My drive does not vary much during the year. Commuting to work mostly.
    If there is a problem with the traction battery, you will find out soon enough. The dreaded evil satanic red triangle will appear in all its malevolence soon enough.
    Until then, don't worry - be happy.
  3. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    ...130K miles? Ugh I got 30K more to go. I will let the EV batt experts answer, but I think they told me rapid charge/discharge is a symptom. Assume you have replaced 12v already? You are quoting cheap prices, somewhere around $2000 gets you a Reinvolt 3rd party recond batt good reputation.
  4. fotomoto
    fotomoto Senior Member
    5,637
    3,812
    So. Texas
    Have your accessory 12v battery checked; preferably load tested. How old is it? Original?
  5. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Here's instructions on checking the 12V battery:
    http://www.elearnaid.com/12vo1topraub.html
    Also, it might be possible the traction battery calibration is off. Disconnecting the 12V battery, then reconnecting will cause it to recalibrate and may solve the problem. Note that you'll need to recalibrate the auto up/down window function after disconnecting the 12V battery (see the owner's manual) as well as set the clock and you'll lose the MFD info history.
  6. ryogajyc
    985
    165
    Reseda, CA
  7. climateguy
    65
    Santa Fe, NM
    For those asking about the 12V battery, it's a little under a year old (Optima) and still performing well. 12.84V with no load, 12.10V with load. Also, since this has been an ongoing deterioration over a couple of years and about 40k miles, in which time the 12V battery has been disconnected a few times, I don't think it's a calibration problem (or at least not one that disconnecting the 12V will fix).
    As for a drop in MPG, that's a little difficult to answer. It seems like over the past few months, it has dropped a little, but it's also winter. Kind of seems a little lower than past winters, but I wouldn't swear to that. Certainly no marked decrease in MPG.
    Well, that's what I've been doing. Unfortunately, that's not really an option any more. The lack of power going uphill means that my wife ends up doing 45 mph on the freeway everyday for her commute, which is both annoying and unsafe.
    Another question: I contacted one of the eBay sellers because he has a listing for a battery from a 2009 with 1,800 miles on it. Seemed like awfully low mileage for a 2-3 year old car. He stated that he's swapping cells from a 2011 into the case from an '04-'09. Are there any potential problems with that?
  8. climateguy
    65
    Santa Fe, NM
    Just wanted to provide an update. I ended up buying a salvage battery off eBay from a 2009 with 17k miles ($700 + $150 shipping). Changing out the battery was really not too difficult. Going slow and being very careful, the entire project took me about 4 hours, but it can definitely be done much more quickly. The good news...my Prius is now back to running like it should. It climbs hills like it did when new, and the SOC changes at the relatively slow rate indicative of a battery in good condition.
    I think the underlying issue is my wife's commute. Elevation changes between home and her work are such that even when new, the battery would go from 1 bar to 8 bars, back to about 2 bars, and then to about 4-5 bars. This is then reversed on her drive home. So the battery gets fully (within the ~40% limit) charged and discharged about 4 times per work day. Eventually, this just led to decreased capacity to the point where the ICE was frequently all that was left to provide power.
    Bottom line - it's possible to have an HV battery "failure" without any error codes. This diminished capacity, though, is probably not something a Prius in the flatlands would experience until after several hundred thousand miles. (Incidentally, I checked the module voltages of the old battery after it had been sitting for a couple of weeks out of the car, and they still all read 7.88 to 7.92 V.)
    Many thanks to all the Priuschatters for making this such a great repository of information, which ended up saving me a few thousand dollars from having to take my Prius to the dealer for a new battery. Thanks especially to Seilerts for his tips and helpful posts.
    2 people like this.
  9. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    Good to hear the problem is resolved by swapping in a healthy salvage battery.
    Here's a tip to keep your salvage battery healthy: On the downhills for your wife's commute, if you want to protect the battery against too much charge from regenerative braking, consider using B-mode before the charge hits 8 bars. It will cost you a bit of fuel economy, but it may prolong the battery's life.
    Also, I don't know if Toyota still offers a $200 bounty for returning an HV battery, but if they do, call them and claim the bounty. It's money in your pocket. :)
  10. ryogajyc
    985
    165
    Reseda, CA
    Is the battery fan on a lot to try to cool the battery? If so, perhaps the fan is clogged with dust and unable to keep the battery cool, leading to early battery death. See this post which links to the relevant info:
    http://priuschat.com/forums/gen-iii...n-replace-battery-fan-filter.html#post1160785
    It may be a good idea to check it out to make sure your new battery doesn't suffer the same fate.
  11. Flying White Dutchman
    4,376
    313
    really strange.. 45mph and the prius sets no DTC or you get no red triangle?
    is this like BIG% incline hil? even then.... 45mph?
    did you check the battery fan? like is it dirty
    what about your tire pressure?
    oil?
    well you replaced it already... interesting situation
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Thanks for the update climateguy. Unfortunately I think you're correct, that Prius's driven in very hilly terrain where the battery gets bounced around from below 3 bars to 8 bars and visa versa several times per day, are more likely to suffer early battery failure.
    It's also interesting to see that you can get definite drive-ability issues and yet the degradation be insufficient for Toyota to diagnose. We had another guy here recently that complained of the same issue climbing hills (I'll try to search the thread later). He spent months chasing the problem and complaining to Toyota, who tested everything (incl HV battery) and kept telling him nothing was wrong. Only through sheer persistence he eventually got them to put in a new battery under warranty (even though they insisted there was nothing wrong). Guess what, fix the drive-ability issues straight away.
  13. uart
    uart Senior Member
    4,220
    1,211
    Australia
  14. climateguy
    65
    Santa Fe, NM
    For those asking about the battery fan, I thoroughly inspected it and the duct work during the battery swap. Clean, no restrictions, and the fan is operating as it should. Tire pressures are 42/40 psi. The hills are not huge gradients, but are significant and fairly long. I'll see if I can attach a terrain profile.
    Again, I think this is just a limitation of current battery technology...the more it gets charged/discharged, the faster it's going to lose capacity. I see this in all my other rechargeable batteries, so why should the Prius be different? (Interestingly, I noticed that the Prius battery modules say "Do not recharge" on them...weird!)
    @justlurkin - Interesting idea about using "B" mode. I wonder what the cost/benefit breakdown of that would be. At any rate, though, if this battery lasts me another 130k miles, I might be ready for a new car by then (but I love this one!).
  15. climateguy
    65
    Santa Fe, NM
    @uart - Yeah, I remember seeing that post and thinking, "that sounds like my battery!" At that point, mine was not yet causing serious drivability issues, but clearly our batteries failed in similar manners. Unfortunately for me, no warranty coverage...maybe I should have been more insistent when I took it in to the dealer at 99k miles, but it was pretty clear they weren't going to do anything without it generating DTCs and my only having noticed a slight drop in overall capacity.
  16. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Hi Neighbor (climateGuy),
    The deep discharges of the battery can be attenuated by picking up speed before the uphill and then driving up the hill with close to maximum ICE power and low battery contribution. I have to be in the right lane for this to work, and I do lose speed on the way up, similar to a truck.
    My other accommodation for the battery is to ventilate the cabin as much as I am comfortable with. I figure if the battery is going to work hard it should be cool ;)
    Lastly, Seilerts has pointed out in other threads the importance of not parking the car in the heat on a full battery. Heavy use is one thing, overheating is much worse.
