Electricity cost per KW hour
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by alfon, Mar 26, 2012.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    We live here in the Northwest and nearly all of our electricity
    is generated by water power on the Columbia river.
    Our current KW cost is about .07 per KW hour. So if a Prius
    takes 3 KW of electricity and you go say 11 miles that was a
    cost of electricity of only .21 cents. That less than .02 cent
    per mile.
    Now am I getting this right???
  2. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    You are correct! And, without trying to hard, you should be able to squeeze out more than 11 miles/charge (it isn't that hard). You'll be doing even better!
  3. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    And if a $4 Gallon of Gas can get you 44 miles, it will only cost you .84 to .92 cents using 4 charges. Go PIP !!!
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Other than the correction I added in bold inline, exactly right.
    watt is power
    watt*time is energy
  5. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    About right, though you should include your taxes and the appropriate share of the fixed costs from your bill. My raw off-peak rate is .049/kWh, but with share of infrastructure costs and taxes its more like .06. Still a significant savings.
  6. pfile
    pfile Member
    319
    35
    bay area, ca
    man you guys are lucky, here on PG&E right now the top tier is $0.33940/kwh. assuming 250wh per mile, that means the cost of operation is 8.485 cents/mile on electric. at 50MPG electric does not become cheaper than gas until gas is $4.25 per gallon. which it kind of is right now around here, but not by too much.
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    If I was not already motivated to conserve or place PV, a marginal use rate that cost 34 cents a kwh would push me over.
  8. psusi
    psusi Junior Member
    68
    24
    Orlando, FL
    You are mixing dollars and cents. It is 0.02 dollars, which is 2 cents, not 0.02 cents.
  9. hill
    8,919
    Let me pick a few nits. You're ALMOST getting that right. There is a certain amount of loss. You don't get all of the kW's that you're paying for into the battery. That's the nature of charging. And the older and older your traction pack gets, the higher and higher your loss becomes. Same with colder and colder temps. But if you charge at 240v in stead of 120v - the loss will be less, because 240v charging is more efficient.
