Abs lights are turning on but only when I use Torque
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jimbo69ny, Mar 24, 2012.
  1. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    Has anyone seen this before?
    As Im driving, occasionally, the abs and break lights come on but only when I am using the bluetooth OBD2 connector with Torque running. Its happend 3 times in the past week. Almost everytime I use the app.
    When they first came on I let the app do a trouble code scan and it said nothing was saved in the cpu. When I started the car the lights were off.
    So I dont think anything is wrong with the car because they shut off when I restart the car.
    Any advice?
  2. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    Jimbo69ny:
    This may seem odd, but try unhooking the bluetooth cable when you shut the car off and don't plug it in until after you start the car. Try this for the next few days and see if you stop getting the lights coming on after the first couple of miles.
    BTW - assume you also leave the device the you are running torque on in the car when its off?
  3. Jimbo69ny
    712
    107
    Ithaca, NY
    Yes I have been leaving the bluetooth adapter plugged in all the time.
  4. jpadc
    343
    34
    I actually meant the Android device, not the adaptor. Does it stay in the car also?
  5. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
  6. Jimbo69ny
    712
    107
    Ithaca, NY
    No. I use my cell phone and that never leaves my side. haha
  7. jpadc
    343
    34
    Well, I have this same problem in my car that I have narrowed it down to specific conditions that will reliably cause this condition.
    If I leave the bluetooth turned on on my Android device (that stays in the car) the ABS and related lights will come on reliably after I drive a few miles. They will go back off only if I shut off the car, unplug the bluethooth adaptor and then restart the car before I plug it back in. Of course if the lights are on, regenerative braking is disabled.
    If I make sure that I either turn the Android device off completely, or simply disable bluetooth on the device until after the car is made Ready, I have no problems with the ABS etc lights. This is easy for me to do as Torque has a setting to turn bluetooth off when it quits. That is not something you would likely want, however, if you are using the bluetooth for other things with the phone (like hands free calling).
    In your case I suspect that as you get close to the car and get in, the phone and the adaptor start communicating some before you make the car ready, and on come the lights after a few miles. Somehow I think you need to keep the phone and the adaptor from communicating when the car is not Ready. Likely the easiest way to do that, is keep the adaptor unplugged until after you start the Prius.
  8. Jimbo69ny
    712
    107
    Ithaca, NY
    I never have to unplug the obd adapter. I just restart the car and they go off.
    I also think my regen breaking is still working with the lights on. Ill confirm this by watching the MFD display and the MG1 and MG2 power pids on Torque next time it happens.
    It doesnt seem to cause any problems with operation of any of the vehicle functions. It just makes me nervous that they come on at all.
  9. Jimbo69ny
    712
    107
    Ithaca, NY
    I can confirm that jpadc is right.
    The MG1 power pid does show -3 when regen breaking should be working however I dont think it is. It normally says -7 or -8 when it is regen breaking. The MFD also shows the arrows to the battery but again, I dont think its really working like jpadc guessed.
    Unplugging the obd2 bluetooth adaptor everytime I turn off the car has seemed to solve the problem. However this is annoying. I dont want to have to do this. So I'm thinking I may wire up a relay that disconnects the power to the unit when the ignition is off. This means I will have to find a second obd2 plug. I'll tap into the one thats already there and then plug the second obd port into the adapter. It will also give me the added benefit of hiding the bluetooth adapter under the dash. I think this is the best solution.
  10. Jimbo69ny
    712
    107
    Ithaca, NY
  11. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Pin 16 on the OBDII port is power. I am adding a switch to it! Since my surgery I have not been driving as much as I want, but the battery is getting low. I dropped the maintenance charger on it to keep it topped off.
    A relay that comes on when you power up will be added to my setup.
  12. thatguy
    thatguy New Member
    Virginia
    I experienced the same thing as the OP when I would stop for gas without turning off Torque or the kiwi bluetooth adapter. The car would come on fine but within a minute three yellow lights would come on ( (!), ABS, VSC) and regenerative braking was disabled. I described my issue here: http://priuschat.com/forums/gen-ii-...-brake-brake-warning-abs-vsc.html#post1392900
    A bit later I ran across the suggestion that if your specific protocol wasn't selected Torque might be spamming the OBDII port with other protocols in its search for an ECU.
    This spamming could potentially stomp on or interfere with some ECU-ECU traffic and trip the warning lights. I decided that was a plausible explanation, selected the protocol my prius uses (ISO 15765-4 CAN 11bit 500k baud) in Torque's vehicle profile, and the problem has not reproduced itself since.
  13. Jimbo69ny
    712
    107
    Ithaca, NY
    AWESOME! Thank you for posting! I am going to try this and see if it works. If it does you will have just saved me lots of time and even a little money!
  14. jpadc
    343
    34
    I'll try it too! Thanks for the thought...
  15. jpadc
    343
    34
    Could you call my wife and let her know that? That would really help me out :)
    Not really a guess, you can confirm it yourself with one of usbseawolf2000's custom PID "Brake - Regenerative Torque (lbs-ft)." That one and "Brake - Friction Pad Torque (lbs-ft)" are two of my standard gauges as I like to monitor just how often the crappy roads in this town kick me out of regenerative braking to friction braking whenever the road has some ripples or potholes in it. I should really stop monitoring it as it just makes my driving here an even less pleasant experience.
  16. mikesarebetter
    mikesarebetter Junior Member
    53
    south dakota
    holy crap i just typed up a whole post explaining what happened to me and here someone beat me to it. Pretty much the same thing happened to me. I'm just glad this has happened to others as i feel very relieved now...
  17. Jimbo69ny
    712
    107
    Ithaca, NY
    Yes it worked! I haven't had the lights come on since. Thank You!!!!!!!
  18. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    I never had that issue, probably because I selected ISO 15765-4 CAN 11bit 500k baud. Auto detecting every time take longer so I just selected that.
  19. jpadc
    343
    34
    Setting the default protocol worked for me as well. I never noticed it was a settable thing. Good tip! Thanks. I still find myself turning the program off when I stop as I am used to doing that.
    I really should take some time to learn more about the Torque program itself. I have learned just enough to get usbseawolf2000's custom PIDs working. There are probably many useful controls and features I know nothing about.
    Which makes me think maybe usbseawolf2000 would want to consider adding that setting to Post #1 so people in the future don't experience this problem.
  20. briank101
    briank101 Member
    170
    68
    Western Chicagoland
    I was having this issue with my Gen III and what I found worked was not to go into the Realtime Info (gauges) screen until the 2 ODB blue symbols had stopped flashing on the upper left of the Torque home screen (takes about 20 seconds for me). Again set ISO 157-4 CAN (11bit 500k baud) as the Preferred OBD2 Protocol (last line in the Vehicle Profile Editor.) Perhaps the "Traction control Disable" PID in the custom PIDs I added may be the issue, as it may scan through all of these when first connecting, can't say for sure.
    SFO likes this.
