calculated vs. computer MPG - Please post your results
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 10, 2009.
  1. ryano7700
    ryano7700 Junior Member
    29
    KY
    Do you always use 10% ethanol?
  2. Mendel Leisk
    41,951
    I've been tracking mileage for about 18 months, tank-by-tank and accumulated: 7% error overall. Guess which way?
  3. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Approaching the 70,000 mile mark on our Prius...
    I don't have to guess I already know!
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    It's all that is readily available here. Actually it may not be E10 there. It may only be reformulated. I'll have to check. Thanks for asking.
    Here are the results of my last tank. It seems I am going to average a 5%-6% over-reporting in this car.
    2012 Prius Three w/solar roof
    Miles= 342.3
    Gallons= 6.623
    MPG Displayed = 54.8
    MPG Calculated= 51.7
    Tires= Yokohama AVID Ascend 42psi front 40psi Rear (900miles on them)
    Fuel= Costco 87octane with 10% ethanol
    MPG Indicated vs. Calculated= 5.99% difference
    Temps in the high 30s to high 50s.
  5. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    I've been driving my 2011 Toyota Prius Three since January 8th. I've put over 7700 miles on it during that time. My calculated versus actual mpg has been almost always a constant 5.5 - 5.9%.
    iPad ?
  6. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    LAST FILL UP
    MFD = 53.0
    Calculated = 50.1
    MFD vs. Calculated = -2.9
    % Error = 5.47%
    Seeing that most of the posts I have read are showing a 5% error, wish we had an option of programing that on our computers. Heck we can plug-in the price of gas at least.
  7. Bawb Hoss
    Bawb Hoss ...... V8 Biker ......
    22
    P6C 3K2
    HSI - 3.7 L/100kms - 76.35 mpg cdn - 63.57 mpg usd - 7100 kms (4411 miles) on car.
    ACT - 4.2 L/100kms - 67.54 mpg cdn - 56.24 mpg usd - 990.7 kms (615.59 miles) on tank.
    41.435 liters - 9.11 gal cdn - 10.95 gal usd - $58.80 cdn @ $1.419 cdn per liter !!!
  8. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    At today's x-rate in Germany we are today at exactly 8$/gal (or 1.6€/L)...
  9. commuter
    commuter Untitled
    (This is my 4th tank in the car)
    491.9 miles
    8.624 gallons
    Displayed 60.9
    Ave speed 31
    Actual 57.03
    Difference -3.87 mpg or 6.79%
    The miles to empty display showed 92 miles to go, but I wasn't about to push the car for another days commute. (@75 miles RT).
    This pace may be unsustainable, but at least in a few years time I can look back at these numbers and be quite happy! If it levels off considerably to the mid 40's I would still be pleased.
  10. yueq
    yueq Junior Member
    MD
    452 miles
    Displayed 52.2 mpg
    Calculated 48.7 mpg
    Error 7%
  11. Brett.
    Brett. Junior Member
    134
    26
    MY first tank in the new car:
    507.3 miles car took 8.93 gallons of fuel
    HSI = 58.8
    Actual 56.8
  12. pacohaas
    pacohaas Junior Member
    56
    2nd fillup, 9.57 gallons, 489 miles: 51.1mpg
    Car said 54.6 on the trip meter, seems like they should be able to get this right, don't you think?
  13. Bawb Hoss
    22
    P6C 3K2
    :amen:
    No Sh--!!!
    HSI - 63.57 mpg usd
    ACT -56.24 mpg usd
    Fill up #9
    :popcorn:
  14. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Fill up = 10.021g
    Computer mpg = 56.1mpg
    Odo = 0 - 535mi from full to empty(0 mi left)
    Calculated = 53.39mpg
    90% Eco mode and 10% Normal mode.
  15. edroun
    edroun New Member
    Omaha, NE
    First fill up:
    335 miles car took 6.71 gallons of fuel
    HSI = 51.1
    Actual 49.93
  16. 6dogs
    6dogs New Member
    33
    NC
    my 2nd tank of gas
    2 pips left
    Miles: 501.1
    gallons:8.328 to 1st click
    computer: 60.9 mpg
    calculated by Fuelly: 60.2 mpg
    decently spot on. My last tank the calculated was about 2mpg more than what was on the display.
    Used NON ETHONAL 89 & filled with same at same station.
  17. pacohaas
    56
    I have a theory on this. The HSI only updates when you're actually moving, or at the very least when you're out of "park". So perhaps when you're in not moving but the ICE is running, you're burning gas that the HSI doesn't count towards its MPG calculation.
  18. HaveNoCents
    HaveNoCents Conservative Tree Hugger
    299
    48
    Crystal Beach, Texas
    Nope. The HSI Does update when you are not moving. I have to take a ferry everyday. On really hot days I will leave the car in ready position. It remains in ready position for about 45 minutes. It is not unusual to lose .4 mpg by the time I have to exit the ferry.
    iPad ?
  19. pacohaas
    56
    I'm guessing you're in Park and don't just have your foot on the brake the whole time? Oh well, so much for that theory.
  20. HaveNoCents
    299
    48
    Yep, I'm in park. It really costs me more than .4 when I consider my car has to recharge the battery totally when I get off the ferry. Obviously the .4 is not totally accurate because it would be dependent on how many miles I already have on the current tank.
    Personally I think the difference is in the pump stopping point, and because of such a small tank. There can be more than a .5 gallon difference which is really significant I'm going to start filling it to the top for a few fill-ups just to see how much difference there really is.
    iPad ?
