2010 Prius with Modellista Aero Kits
Discussion in 'Gen 3 Prius Main Forum' started by Lafferty, May 19, 2009.
  1. Lafferty
    Lafferty Member
    163
    67
    Pacific Palisades
  2. Lafferty
    Lafferty Member
    163
    67
    Pacific Palisades
    Found a couple more renderings at Motor Trend.
  3. Matt Herring
    Matt Herring New Member
    421
    51
    North Andover, MA
    Any documentation on how these "aero kits" improve aero?
  4. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Gee, can we 'uglify' the front end even more? I already don't like the gaping lower 'grill' on the stock model. At least it isn't as big as the one on the new Insight.
  5. Lafferty
    Lafferty Member
    163
    67
    Pacific Palisades
    Yeah, that grille in the bottom pic isn't very attractive in my opinion.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Some of it looks sweet, some does detract. I'd be concerned about overall Cd changes compared to improved handling.
  7. Matt Herring
    421
    51
    North Andover, MA
    In my opinion, these kits increase drag. Fine line between looking cool and mpg but this one gets a thumbs down from me on "aero." :mad:
    The only "aero" improvements that might be had are the upper grill block on the one and the side skirts on the other. The rest look like they eat air, trap it in the car and increase drag. These are definitely not "aero" kits...they are "bling kits."
  8. Tideland Prius
    16,615
    Kinda looks like a Mazda3 with that new kit for the front.
  9. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    How about a lower grille block that opened when needed? That actually would be 'aero', as well as improving aesthetics and thermal efficiency.
  10. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I think it would have to fill the space rather than just block the air from flowing through. Otherwise the increased flat front surface would INCREASE Cd.
    But, that is what I WANT Toyota to do. Put in an automatic aerodynamic, ICE temp based, blocking feature. They presumably want a low emission, high MPG car, why don't they do something to automatically keep the ICE at the desired temp in both hot and COLD weather??
  11. 1SMUGLEX
    1SMUGLEX I love the smug!
    315
    51
    Atlanta
    depending, aerokits can help/hurt drag. they won't affect handling unless they weight 500lbs :D
    I like them.
  12. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    +1. Pretty simple thermally actuated louvre system. Heh, I say "simple" as if I could build it! But for someone with the right skills and resources, probably not too tough.
    - D
  13. harry r
    harry r slowly turning green
    122
    NW of chitown
    interesting ideas. kinda have me thinking of some type of black foam pieces to be wedged in between the horizontal strakes of the lower area..
  14. Ted in Olympia
    Ted in Olympia New Member
    84
    Olympia WA
    They do not look that much better/different to me to be worth using. Also Toyota spend a lot of effort to get the drag coefficient down to .25 and I would want to see some wind tunnel testing to show that these are even better. I would bet that these "aero" kit makes it a lot worst.
    IMO if you want to do something like this to a car you should buy a Mustang or some other "sports" car. When you get done putting an aero kit on a Prius, you still have a Prius.
    TED
  15. garylow
    garylow Junior Member
    new jersey
    Instead of blocking the air that would increase drag why not use it to divert the air to keep block hot and open when it needs to cool it down? A y shaped duct with a flap that is controlled by a temperature controller to switch where the air goes depending on block temperature and/or outside temperature? Just a thought.
