Cheap, easy, no-assembly charging cable security!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SCDrJ, Apr 2, 2012.
  1. SCDrJ
    SCDrJ New Member
    120
    Orange County, CA
    PIPers -
    I have spent some time looking at the concept of securing the charging cable while at work, and perused the threads related to the subject... I did not want to modify my car's charging connector and also did not want anyone trying to "jimmy the handle" with a small lock on it, so I was going for more of a cable tie-down.
    I basically took john1701a's idea (see thread called "securing the charging cable) and looked for a product that did it all in one shot - I found this at REI for $12. The lock and the cable come in one package, and only requires one key. The cable is all plastic-coated to avoid rim damage as well. Neither end of the cable can pass through the small lock hasp.
    Hope this helps a few of you who charge away from home - maiden voyage to work tomorrow for this setup!
    Photos are below:
  2. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    My preference is the lock through the handle hole.
  3. fjpod
    fjpod Member
    419
    72
    New York
    I'm thinkin that lock is real easy to cut, and close to the ground so as to be well hidden for the two seconds it takes to cut it.
    I would go with something that would require the thief to damage the charging cable.
    Maybe thread a loop of the charging cable through the wheel spokes and just put a real heavy lock on the loop.
  4. gramps
    gramps Member
    195
    44
    Southeast Texas
    Just a quick piggyback on OP's idea. It Is not cheaper or necessarily better but, I already have a heavy duty bicycle lock . It came with the same type cable . It is the big "horse shoe" shaped locking device.The cable is designed to go around the tire rim (looping through itself) then you put the other cable end on the "horse shoe" lock before locking to a stationary object. The lock is much more heavy duty than the one pictured. The brand is Kryptonite, price is expensive (about $35-40) it came with a $1000 warranty. Of course it can be defeated by a professional thief.
    It has multiple possible uses to secure the charging cable.:(
    Now I just need a PIP.
  5. stephens5.rich@gmail.com
    [email protected] New Member
    39
    Los Gatos, CA
    If someone really wants it, they will get it, just like the car itself. The benefit is to slow them down or seter them from trying. I made something similar where one end ot the cable is actually hard fixed to the cable and the other end goes through the wheel and locks back to the cable. Less than $10 with the lock but enough to slow someone down or deter them altogether, unfortunately myabe on to the next car without a lock!
  6. SCDrJ
    SCDrJ New Member
    120
    Orange County, CA
    Exactly. A pair of scissors can snip the cable and defeat any of these measures if someone really wants it (or wants to vandalize it). Discouraging the casual thief is about all we can do. I am considering lowering my comprehensive deductible a little bit (maybe to $200 or $250) in case a cable gets stolen.
  7. gramps
    gramps Member
    195
    44
    Southeast Texas
    Picture of a newer version than mine.
      File size:
      38.6 KB
      937
  8. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    The $6 lock in the plug's hole is my answer.
    But if I was looking for More Security I would get -
    Mr. Clean !!!
  9. priusenvious1
    priusenvious1 Member
    325
    37
    LA
    I just bought this from Amazon. Thanks for this tip. That little luggage lock wasn't giving me piece of mind.
  10. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    I have heard of one PIP user who's plug was removed from the port while charging, but not damaged.
    Has Anyone had their Charging Cable stolen or damaged?
  11. RBooker
    RBooker Member
    154
    56
    "someone really wants it, they will get it, just like the car itself."
    I thought one of the paired remote is required to start a PIP.
  12. lensovet
    2,615
    496
    Burlington, NJ
    same way a key is "required" to start older cars. the point is that a determined thief will defeat any security system.
  13. CharlesH
    2,796
    1,163
    Roseville, CA
    Just curious, is the kind of security system used in the Prius something that requires a sophisticated professional car thief to defeat? I guess that it depends on what the thief's objectives are. If it is just to get it to a chop shop to break it down for parts, then there is not much that can be done about a thief with a flatbed who will just pick up the car and take it away.
  14. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    What do you think about just driving over the cord? Do you think doing that long term will make the cable deteriorate?
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yes!
  16. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Note to Toyota:
    Here is a simple way to build a locking mechanism on future cars. Put a small hole in the bottom of the charging port area that leaks to the ground but pops up into the side of the trunk. A looped cable can then be put around the cord and go into the trunk where it is locked or hooked on something. This costs almost nothing per vehicle and gives many options for locking.
    Mike
  17. ETC(SS)
    7,134
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    lol, gud wan:ROFLMAO:
  19. usdmattiphone
    usdmattiphone Member
    147
    58
    I had my $40 extension cord I used to use to reach the plug stolen, but my charge cable was left alone (it had the cheap $6 luggage lock on it). Now I have a private garage where no lock or extension cord is needed.
  20. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    Thanks ... This worked well for me today...cost 9 bucks for everything. Now I can plug in at work and not worry.
