Wide angle (split) door mirrors now available
Discussion in 'Prius v Accessories and Modifications' started by DBS, Apr 2, 2012.
  1. DBS
    DBS Junior Member
    37
    Staunton, VA
    Four Touring
    These are now available. See Ebay listing numbers below. These really help with the side mirror viewing area.
    Subject: RE: GENUINE TOYOTA PRIUS v LH drive wide angle door mirror
    Thanks,
    I have listed them on ebay for you the item numbers are 251032858316 and 360447909814. they are £58.84 + £20.00 delivery to the States each, but should you wish to buy both we can combine postage for you.
    Regards Shaun.
  2. tanasit
    tanasit Member
    399
    60
    Philadelphia
    I am a little concerned because if the LHD was designed for the left hand drive in England, then it will be too wide for us in the USA. 16 years ago I was the very first who traced my side view mirrors and had them custom made for wider angle view and I was told that the one close to the driver (left in the US) must have less curve than the one on the right hand side otherwise the objects in the left hand mirror would be TOO small and looked like they're far away which in fact was not the case. Are your products were specifically designed for the US traffic?
  3. DBS
    DBS Junior Member
    37
    Staunton, VA
    Four Touring
    These are not my products but genuine Toyota mirrors from a dealer in the UK. You can email them your Vin# and they will verify the fit. I use them on my 2010 Prius and I am very happy. I bought them from this same dealer. I just ordered a set for my Prius v3
