Charging at SFO
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by tarantoga, Apr 2, 2012.
  1. tarantoga
    tarantoga Junior Member
    52
    Alameda, CA
    I picked up a friend at the international terminal at SFO - they had 2 chargers right next to the walkway between the garage (hourly parking) and the walkway to the terminal (probably more on other levels).
    This was pretty much the closest you can park to the terminal, so it was a great perk. Charging was free, but of course parking is not.
    The annoyance with a PIP - the cable had to be slung over the hood or the roof to reach the plug. Since it's diagonal parking in a cramped garage, there was no way to back in.
  2. pfile
    pfile Member
    319
    35
    bay area, ca
    is it a chargepoint station, blink, or something else? thanks.
  3. tarantoga
    52
    Alameda, CA
    Chargepoint
  4. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Call ChargePoint... 1-888-758-4389
    They would appreciate feedback about poor implementation and pass on a suggestion to the owner, like making some space for perpendicular parking in those spots.
    Keed in mind that most owners have the hope of expanding later (adding more stations), since the initial wiring investment is very expensive. So, they'll probably be rather receptive to complaints from users.
  5. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Is it impossible to back the car into the spot at SFO?
