Map display problem
Discussion in 'Prius c Audio and Electronics' started by Lighthouseguy, Mar 29, 2012.
  1. Lighthouseguy
    Lighthouseguy New Member
    Newport, OR
    The nav system works OK in the Prius C....although the one in my former Prius Liftback was superior. But...the Prius C map display is very dim & cannot be seen when the vehicle is in bright sunlight. The nav manual shows no adjustment that effects the map display. Any suggestions?I
  2. MBRGuru
    MBRGuru Member
    255
    26
    Try tweaking the screen settings in the Setup screens. Might help somewhat.
  3. PriusRoadWarrior
    76
    Wisconsin
    Agree, use setup and tweak the 'Contrast':)
