2012 PRIUS C3 17" Black Drag Wheels
Discussion in 'Prius c Main Forum' started by PRIIC3, Apr 4, 2012.
  1. PRIIC3
    PRIIC3 New Member
    25
    Scottsdale
    17" wheels are on and they fit well, no spacers needed.
    B. Roberts, PlacerLode and ewaboy like this.
  2. EVOX
    EVOX New Member
    24
    So Cal
    What size tires you got on? Where did you purchase rims/tires and what was the cost?
  3. PRIIC3
    PRIIC3 New Member
    25
    Scottsdale
    Michelin 215/45/17
    I found the best deal at discount tire and used a friends wholesaler liscense. Wheels were about 115 a piece. Tires were about 180.
    1180 total before taxes.
  4. Tek55
    Tek55 Junior Member
    96
    Houston
    How is the turn radius? Any rubbing?
  5. PRIIC3
    PRIIC3 New Member
    25
    Scottsdale
    good, there's no rubbing what so ever.
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I think it'd look bad nice person with a Prius 17 inch rims.
  7. R11
    R11 New Member
    101
    17
    Portland, OR
    I'm not flaming, just curious :), but why do you want expensive, high performance rubber on such a low powered car? Just for the looks?
    ron
  8. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
    For me it would be for increased cornering grip, but I personally would not want to sacrifice the mpg to get it.
    Why would the corning forces be any less/more at 30 or 50 mph in a car with 100 or 300 hp? For cornering, the wider/stickier rubber would definitely be a performance upgrade, but I would be more concerned with how the extra drag from the heavier wheel/tire combo, increased width track of the tires and stickier compound will drag the mpg numbers down. It's always a trade off and one that each owner makes when modifying their cars based on the car's intended use.
    DRWatson and halcb56 like this.
  9. R11
    R11 New Member
    101
    17
    Portland, OR
    Well, typically the softer compound tires make the most difference near the limits of adhesion, which usually translates into carrying high speed into and powering out of corners, and also under hard acceleration on the drive wheels when not in the turns.
    ron
  10. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Wow didn't think it would not rub since the factory 16" do and radius was changed a little were changed. I think the offset is different and comes out more maybe? Let us know how your MPGs are with those. The factory 16" have great grip and more then enough for me but I am buy a lighter wheel down the road to the exact factory size.
  11. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
    My experience has been that a higher performance/softer compound tire will elevate the cornering feel and grip ability throughout the entire turn, not just entry and exit. It just "sticks" more throughout.
    I totally agree that in straight line performance the higher grip allows for more power to be transmitted to the ground before slippage, which prii most likely would not benefit from.
  12. bretaz
    bretaz Member
    475
    52
    Surprise, Arizona
    I put Michelin Pilot Sports on my 2010 with 17" wheels. Looked good but killed the mileage. I dont think it was the size of the wheel as much as the tire, but there werent many tires to choose from.
    When I was looking at the C, I was thinking that was the wheel I would use but keep it at a 15.
    Looks very nice.
  13. madfast
    madfast New Member
    45
    28
    NY
    17x7? offset? notice any change in acceleration?
  14. madfast
    madfast New Member
    45
    28
    NY
    fwiw if you check out the track, the 16" wheels actually have a shorter track vs the 15" wheels. this means the offset is actually larger on the 16" wheels than the 15". that means most of the width gained is on the inside. that's why they had to increase the turn radius (less turns lock to lock) and that's why they had to compensate with a quicker steering ratio. aftermarket wheels will have a more aggressive offset and so you can fit much larger wheel/tires and not rub.
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    Looks good. :) I'm sure you're loving the handling difference but hating the mpg loss. Or you will be soon. lol
  16. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Don't know why everyone's worried about rubbing. From the picture, you seem to have more clearance than Patraeus at the CIA.
    2 people like this.
  17. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Wheel/tire combination looks beefy on your c... excellent, even. A definite improvement filling out your wheel wells! Great picture.
    You haven't mentioned the wheel offset, but you can show us by taking another picture of your car, wheels pointed straight ahead and camera pointed right down the side of the car, to show if the wheel is flush with the wheel well fender line.
    Make sure you optimize your tire pressures to get the most MPG you can out of that c. It would be interesting to hear what you average with this new set up.
  18. PRIIC3
    PRIIC3 New Member
    25
    Scottsdale
    As of today, I took the same drive to the office 22miles both city and highway and got 51MPG. Yesterday was at 53MPG. I'll take a few other pictures later today and post them as well.
    2 people like this.
  19. B. Roberts
    691
    212
    Not bad MPG with those wheels/tires! More pics would be great.
  20. F8L
    19,011
    4,083
    Grass Valley, CA.
    Agreed. Hopefully he racked up a decent amount of miles before swapping the wheels so we can get a real average difference in mpg. These quick swaps just don't give us any useful information.
