Tire Rack Now Has Wheels Listed for Prius c
Discussion in 'Prius c Accessories and Modifications' started by kkim, Apr 3, 2012.
  1. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
  2. beerme
    beerme Repeat Offender
    42
    Norcal
    Sweet! Thanks for the heads up! I was just there yesterday looking and nada.
  3. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
  4. Lenwood
    Lenwood Junior Member
    53
    san Mateo ca
    Tire rack states that the 175/65/15 tire is ok on a 6.5" rim
  5. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
    Yep, I saw that and am pretty happy that the stock tires will fit my incoming wheels. :dance:
  6. BrunoPuntzJones
    107
    28
    I'd really like some white 15" in place of my stock 16"s. Don't want to pay anything though :D
  7. cubchan
    cubchan Junior Member
    42
    Indianapolis, IN
    I've been shopping for wheels and have noticed that moving to a 16 or 17 inch rim will change the outer diameter of the tire to 23.7 or 24.3 instead of the 24in diameter of the 175/65/15.
    Does anybody know how much this would affect the speedometer or odometer?
  8. Daze
    Daze Prius C Owner
    92
    Utah
    What effect do different sized rims have on the turning radius and mpg?
  9. madfast
    madfast New Member
    45
    28
    NY
    they also state 175/65 on a 7" wide wheel, so i wouldnt exactly trust a computer program just yet... im gon wait until kkim mounts the stock tires on his new wheels. he's our resident guinea pig :D
  10. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
    Yes, I have my doubts if this will work, too, despite what Tire Rack has listed. The wheels are on Oahu right now... should be here on Kauai tomorrow at the post office. Crossing my fingers that I can get the tires mounted tomorrow afternoon and have them on the car by the weekend.
    I'll be sure to take pics and report back once everything has been completed.
  11. halcb56
    halcb56 HalCB
    Asheville, NC
    What wheels did you go with, kkim??
  12. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
    15x6.5 Konig Heliums. Not on Tire Rack's site, but have used these rims on previous cars and they are lightweight, high quality rims, despite what some may think.
  13. TytaniumK
    TytaniumK New Member
    44
    Alabama
    Was also wondering--I really like the BORBET LV4 shown for $130 each~pricy but bitchin':rockon:
  14. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
    My first rule of thumb when shopping for aftermarket rims... make sure they are lighter than the rims you are replacing. Are they?
  15. Absolutly Red Hot
    155
    83
    91
    SoCal
    What is the weight of a stock wheel and tire? How much weight can you trim off by going aftermarket? KKIM will have to hgive us all the details.
  16. F8L
    19,011
    4,083
    Grass Valley, CA.
    kkim already did. You just have to read his other thread where he weight his OE wheels. :)
  17. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
    I've covered this before in other threads, but stock wheel/tire is 32lbs. stock wheel alone was 16.5lbs. I used a lightweight 6.5 alloy rim that weighs 11.5 lbs, so my combined wheel/tire weight was 28lbs.
    http://priuschat.com/forums/prius-c...s/106692-installing-aftermarket-wheels-c.html
    here's a great resource to use when shopping for lightweight rims.
    http://mechdb.com/index.php/15"_Wheel_weights
  18. Absolutly Red Hot
    155
    83
    91
    SoCal
    Thanks for such a informative Thread. I was at the local Tire Shop and found some wheels made by Drag. The style is M33. It is a 7 spoke alloy wheel that weighs about 14lbs. I am thinking about the Black with Red stripe around the lip. It should offset well with the Absolutly Red color. Although Silver is nice as it kinda Pops. Choices to be made. I am staying with the 15" so that I do not mess with the ODO and mileage. Anyway thanks again for all the info.
  19. kkim
    kkim Active Member
    386
    133
    kauai, hawaii
    Cool... pics after you get them installed, please. :)
  20. BrunoPuntzJones
    107
    28
    For those of us with the 16" stock wheels, how do you go about having the rack or whatever adjusted to get back down to the smaller turning radius if you get 15" wheels? This a simple thing the dealership can do?
