Need help with USB and Bluetooth audio
Discussion in 'Prius v Main Forum' started by JRCurrier, Mar 31, 2012.
  1. JRCurrier
    JRCurrier New Member
    Indiana
    My husband and I bought a Prius v3 almost a month ago and absolutely love everything about it. My husband (who owns a 2005 Prius) is totally jealous that it's my car. :D I have one problem that I just haven't figured out though. I'm hoping it's just something obvious that I/we haven't figured out...
    How do I play mp3s from either my mp3 player or podcasts through my iPhone 4? (My previous car was a '99, so this is totally new territory for me.) It seems like it should be just "plug-and-play", right? I've tried plugging my Zen X-fi mp3 player into the USB port, but it doesn't recognize that I've plugged a device in. Then this morning, with my husband, the tech guru, in the car, I tried plugging a USB drive with music files into the port. Still nothing. So I tried seeing if I could play a podcast from my Turn off signatures in Tapatalk Bluetooth wireless and it wouldn't recognize that there was a Bluetooth device available to play on the audio system. What am I doing wrong? I talk on the phone via the car's Bluetooth system, so I know it recognizes that device, even if not the others.
    Any insight would be appreciated. If I don't figure it out by Monday I'll call the dealer, but we're going out of town this week and I really hoped to be able to listen to stuff without having to haul a bunch of CDs around for the first time in my life!
  2. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Go to Setup/Bluetooth/Phone and there should be a category to Setup the iPhone for Music. This is all your iPod functions. I listen to music and my Audible books via the Bluetooth connection.
    For internet you need to hook the iPhone directly to USB. USB port connection also moves the iPod controls to the Prius screen vs. iPhone screen.
    MP3 player I'd think you'd plug in to the Prius Aux connector vs. the USB.
  3. Quentin
    Quentin Member
    335
    West Virginia
    Yep, you have to make sure you set up the iphone for bluetooth audio streaming as well as the bluetooth phone. On my 4Runner, as you set up the iphone, it asks if you want to set it up as an audio device as well.
    Having the entune setup, you should be able to use that to get to your music on your iphone as well. Have you signed up for entune and downloaded the app for your phone?
  4. HaveNoCents
    HaveNoCents Conservative Tree Hugger
    299
    48
    Crystal Beach, Texas
    Under Bluetooth setup you need to select paired devices. If you see your phone you will see three icons next to it. The first is a picture of your phone. If your phone is connected via Bluetooth it will be highlighted. The next icon is for music. Just select the icon and it will ask you if it is ok to hook the device for music. Just select yes, and you're good to go.
    If your phone has never been used with Bluetooth you will not be able to get into paired devices. You will first have to register the phone. You did say your phone works so going under paired devices should be an option that can be selected.
    iPad ?
  5. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    Acutally, some of the stuff you guys told her can be taken a lot of ways.
    You can also use an iPod/iPhone USB connection cable to allow your Prius v to just directly control the player on your iPhone/iPod. Just in case you have had problems with your bluetooth.
    As for the Zen x-fi or the USB flash drive, you just need to have your mp3s put on the root of the drive or in a folder. You may want to make sure your music is encoded to be about 128-320bit, no higher, and I believe with a 22-44.1 khz bit rate. It should also support WMA files and a few others, you should check your manual for the Nav system for the supported audio formats it will support. You will also need to make sure you are in the USB section on your system. Your devices should also be 'hard drive readable' to allow the system to access it and see files.
  6. JRCurrier
    Indiana
    Thanks so much, everyone. I just went down and paired my iPhone for music. The dealer had paired my phone while I was outside the car, so I never saw that I needed to pair it for music as well as voice. To be fair to my husband, he had mentioned that I probably needed to use an aux cord with my mp3 player, but he had never gotten one from his stash of misc cords (and I'm non-techy enough to not really know what I'm looking for). The mp3 player worked, but was quiet. I didn't spend much time in the car this morning, but I think I just need to turn up the volume on the mp3 player. I generally have it quiet since I listen with headphones. Still no luck on it recognizing a thumb drive, but since the others work now, it's not an issue.
    You guys were so helpful! Much more information and much quicker than I would have gotten with the dealer. :)
  7. Keiichi
    808
    79
    Goleta
    The reason the MP3 is quiet for Bluetooth, is that the Bluetooth Media player uses both the car's volume and the player's volume. Think of your car system as one big plug in speaker. Problem with plug in speakers, is that if the player is playing at one volume, the speakers play thinking at that volume. Weak signal (low volume) == weaker signal on the plug in speakers.
    Ideally, I would recommend using the USB to iPhone/iPad/iPod connection, as the nav unit has sort of a native iTunes controller that maybe more ideal to your situation.
  8. pdp
    pdp New Member
    162
    17
    Bay Area, CA
    Actually, I have not noticed any difference between the volume via Bluetooth or direct USB connection with my iPhone 4. I do have the volume on my iPhone at max when using Bluetooth. When connecting via USB, you don't have a volume option on the iPhone.
    But I agree, a USB connection should theoretically give you better sound quality... however due to the quality of the v3 sound system, I doubt anyone would notice.
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Is the drive FAT32?
    My drive was annoying the devil out of me until I reformatted even though it reported it was FAT32. It's been working fine ever since.
  10. wilbur1
    wilbur1 New Member
    Madison, WI
    I am having trouble permanently pairing my phone (not a smart phone) with my car too. i do not understand the "registering" process. hints?
  11. HaveNoCents
    299
    48
    registering is setting your car and your phone ready to accept the other device's information. On the 2012 prius it actually says register on the menu. On your phone it can be called many things. It might just say enable bluetooth, or search for other devices. To pair the devices one of the devices will ask for a 4 digit code. Just enter the 4 digit code and you are now paired. Once you are paired the units will try to connect every time they are within range of each other
  12. wilbur1
    wilbur1 New Member
    Madison, WI
    my phone is listed under the paired devices list so i've gotten that far but something is affecting the ability for the car to pick up the fact that the phone is on and now in the car: to be "connected". frustrating.
  13. wilbur1
    wilbur1 New Member
    Madison, WI
    i appreciate your help but nowhere on the screen does it say "register" and though it mentions a PIN, nowhere on the car or the phone does it ask for one to be entered. it does list a code or something that should match (and does) the one on the other device. i think the phone must be registered because for a time i have been able to use the hand-free feature, until the car is turned off. i'm happy for more suggestions!
  14. HaveNoCents
    299
    48
    Do you have a Prius v with navigation? If you do there is a register command on the Bluetooth menu. If you already registered the phone it should be under paired devices. If it is click the 1st icon to the right of your phone. That represents Bluetooth for your phone. The second icon is for music, and the 3rd icon is the Internet.
    Edit. I see you said it is under paired devices. Ok if the phone icon is not highlighted then select it with your finger and you should be connected.
  15. MarathonMarty
    MarathonMarty Prii 4-timer
    Spokane, WA
    2013 Prius v wagon
    Are you positive that bluetooth is activated on your phone when you start the car. On some phones bluetooth is not automatically turned on when another bluetooth device looks for it. My wife's smartphone, an LG Thrive, is like this. She turns bluetooth off if she is not in the vehicle, to save battery time, and she has to manually turn it on before starting the Prius or the car will not see it. On my non-smartphone, a Motorola Krazer, the car communicates with my phone and my phone turns bluetooth on and they are automatically paired.
  16. wilbur1
    wilbur1 New Member
    Madison, WI
    i know the screen you are talking about. no, the phone icon is not lighted, though one time it was. it has not done anything when i've touched it. i'll try again.
    thanks!
  17. wilbur1
    wilbur1 New Member
    Madison, WI
    the phone bluetooth is always on.
