Prius Died on HW; Diesel they say
Discussion in 'Gen 2 Prius Main Forum' started by unregistered4, Apr 9, 2012.
  1. unregistered4
    unregistered4 New Member
    My 2009 Prius died on Saturday 4/7 mid-ride. Triangle of Doom appeared, as well as warning notice on MFD that looks like a car with an ! in the middle. Had to be towed back to a dealer.
    Report today is that my gas tank was filled with diesel. That would explain the trouble with the ICE, but hard to reconcile with my experience.
    I filled the car up from a flashing pip on 4/2. I drove 200 miles without trouble before the car broke down on 4/7. I always thought that gas station diesel pumps had a different bore to prevent mistakes, and if somehow you found a way to make one and filled up a gas engine with a full tank of diesel, you'd be lucky to start the car, let alone drive 200 miles on it without trouble.
    Any theories from our resident experts on whether the dealer is on the right track?
  2. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    !! Sorry to hear about this. I am no expert to advice on anything, but I hope they 'fix' whatever is broken and hope it won't cost you much.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    If it was diesel your car will have been smoking badly before breaking down. If it was a small amount of diesel you might have been lucky and not caused much damage if any, but you'd be amazed how much diesel you can mix with petrol and have the car still run, though it will be causing significant damage to your emissions equiptmen. The more diesel mixed, the more the car would pump out lots and lots of grey, black smoke.
    I fear you may have learnt an unfortunate and expensive lesson now that diesel pumps are becoming more prevalent in the USA. Misfuelling has become a big problem over here in the UK;
    Filled with the wrong fuel? | AA
    The AA are the UK version of AAA. Here unleaded pumps and pipes are green and the nozzle smaller, whereas diesel pumps and pipes are black with a wider nozzle, but still people missfuel. In fact a couple weeks ago I just managed to stop a lady putting unleaded in her diesel Golf who was filling up next to me.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    You say you filled up from a flashing pip?
    So that would be a pretty full tank of whatever you put in last.
    I'd check out the gas station you last filled. There are rare stories of Gas Stations getting the wrong gas in their source tanks.
    Otherwise, weird happening but what do you do?
    I would think if you had a full tank, of full diesel you would of noticed symptoms right away.
    But perhaps, if it's a gas station problem, with a mixed amount in their tanks?
    Best of luck, that's a strange story.....
    PS.
    You say "You" filled. So I'm assuming you don't live in a State like Oregon that requires an attendant to fill for you?
    In Oregon, an attendant must fill. So I always stick around to see what nozzle he is actually using. Never had them accidentally use Diesel, but have had them pump Premium when I wanted Regular.
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    A location would help a lot for particular details. Every diesel pump I have seen is bigger and would fit into a normal car. As a construction worker I've pumped more diesel into big trucks than normal petrol in my own car. (only takes a few tanks). I don't get how a person could make the mistake. I assume it was the stations fault. I've been across the US and I'd say there are some really dumb people running gas stations. (what ever happed to professionals that took pride in their work therefore a singe guy could build or rebuild the place from the ground up?)
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    Santa Fe, NM
    We had that happen here a few years ago, where a tanker was filled with diesel by mistake, and make several deliveries to gas stations around town. That's a possible explanation of why you were able to make it that far, if the diesel concentration was not high to begin with but eventually settled to the bottom of the tank (the fuel pump inlet) due to its higher density.
    It should be a simple matter of draining the tank and refilling with gas. Don't let them snooker you into a new tank.
  7. unregistered4
    @The Electric Me: I filled up. Can't blame the wife on this one, or an attendant either. I plan on taking a field trip to the station to examine the diesel nozzel on the way home. Operator error is always possible, I guess, but I think the station uses pumps that simply will not fit in my tank.
    @GrumpyCabbie: No smoke. No performance issues of any kind for 200 miles until it died. Which is why I'm a bit suspicious of the feedback I'm getting from the dealer.
    @V8Cobrakid: I am in northern Virginia. And like you, thought (and still think) that this kind of diesel in a gas engine mistake is hard to do with the pump sizes, etc.
    A co-worker's hypothesis is that a no-good kid in the neighborhood spiked my tank as a prank. But from what I've read a gallon or two from a hand tank probably wouldn't be enough to cause these problems. I had over half a tank when it broke down to mix in with.
    Thanks to all for the feedback and well wishes.
  8. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    You'd be surprised how far a car can run with a high concentration of wrong fuel in it.
    I know of one person who drove their Range Rover diesel 20 miles from cold before it finally went bang. Apparantly that had performance issues that got steadily worse.
    I also know of someone who filled up half a tank of diesel into a petrol car. It too ran and ran ok but did fill the air with thick smoke.
    I would be surprised you managed to drive 200 miles on diesel if you filled up from 1 pip. It sounds like others have suggested - that the fuel you purchased had been contaminated with a small amount of diesel causing you to be able to drive, but slowly fouling the oxygen sensor which caused the car to breakdown.
  9. fuzzy1
    10,421
    Was the tank actually full, or was half empty?
    If it was nearly full after you went 200 miles from the last fillup, I'd suspect vandalism while it was parked.
  10. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I would be, too. Going from fine to dead seems unlikely. BTW if you filled a car with diesel it would definitely start, though, because there's gas in the fuel lines and pump.
    Should be very hard to fill with diesel as the bore is indeed bigger.
  11. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Has anyone been able to figure out how to open the Prius gas lid without flipping the inside switch or tearing it up in the process?
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    That's what I was thinking Tony. Surely there would be signs of tampering.
    Also, if someone was that determined to vandalize your car then there are more destructive options that require less effort.
  13. unregistered4
    Agree with @Tony and @uart on the vandalism thing. Sort of hard to imagine that someone would be walking around with a few gallons of diesel fuel looking to make trouble by pouring it down the locked tank of someone in a residential neighborhood. Which seems to leave open (1) contaminated regular gas with just enough diesel to cause problems or (2) a dealer finding something non-warranty related to justify the breakdown.
  14. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    Sounds like a gas station issue. Most diesel pumps are nasty and the larger nozzle makes it hard to mistake.
    This makes me want to keep receipts from fuel....
  15. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I like the way you think, a healthy dose of dealer mistrust. ;)
    Got to admit, that option did cross my mind as well. :D
  16. caymandiver75
    caymandiver75 Member
    192
    101
    Northern VA
    2019 Prius Prime
    I'm also in N.Va. Out of curiosity, which dealer did you take it to and do you recall the last station you filled up at? If it was a station issue there would surely be others on the road with the same issue.
  17. Patrick Wong
    18,200
    6,502
    It is true that diesel fuel pumps usually have a larger-diameter dispenser so you typically would have to try very hard to pump diesel fuel into a gasoline engine vehicle that has a restrictor in the fuel tank inlet.
    I would smell the fluid to see if it smells like gasoline, diesel, or ??
    I agree that if the fuel was diesel, the car would have likely shut down shortly after starting up. Perhaps the fuel was just slightly contaminated?
    In any event, the likely repair should be to pump the remaining old fluid out of the tank using the car's fuel pump and connecting the fuel rail to a hose - then refuel with gasoline. If the car works at that point, then I would accept the mechanic's diagnosis.
    I would then suggest that you should file a claim with the fuel station that you last bought fuel from after you have gotten a repair invoice which documents the mechanic's findings.
    I really doubt that vandalism is involved. Tampering with the fuel tank via the locked door is difficult and there are much easier ways to vandalize your car - kick a door with a steel-tipped boot, run a key or knife edge along the paint etc etc.
  18. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    If it was me I would get a sample of fuel if possible.
    Probably they are claiming diesel due to color of fuel.
    You know what gaso looks like.
    ULSD I am not sure but maybe it is red dye?
    In any case, if you had a sample you could sniff or even analyze.
    The only thing comes to my mind is the Toyota coolant is red.
    But I cannot think how that gets into gas tank.
    Is this a Toyata dealer? I am in NOVA too.
    PS_ you are not telling us gaso brand or anything which makes me wonder if no-name.
  19. unregistered4
    It was a Shell station in Ashburn, VA. Koons Tysons Toyota was the shop. I've got a gas sample. And the Virginia Department of Agriculture (who also regulates fuel quality) is investigating. So science will soon get to the bottom of this.
  20. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Keep us abreast, interesting to follow. I was initially very skeptical of the diagnosis, but if the gas station did fill the tank with diesel I suppose this really could happen. Weird.
