Illuminated Door Sill Instructions
Discussion in 'Gen 3 Prius Accessories and Modifications' started by PracticalEfficiency, Aug 22, 2009.
  1. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    bumpety bump
  2. zebelkhan
    zebelkhan Member in good standing
    165
    Morgan Hill, CA
    Last year a friend of mine bought four 2011 Prii for his company sales team. One of them came with illuminated door sills. Guess which car they are on now..... :)
    Thanks to this thread installation (actually switching the illuminated ones from 2011 to 2012 and vice versa) took only about 20 minutes. Battery was NOT disconnected on either vehicle.
  3. khoakhoa
    khoakhoa Junior Member
    96
    28
    san diego
    Video for Rear Install of:
    Plugin PIP 2010-2012 Toyota Prius Illuminated Door Sill Protectors
  4. GoldPianoGarden
    841
    74
    98
    Brunswick, GA
    So, what makes these light up if you just pop them into the holes? Are there pre-existing contacts built into the car and the door sill protectors that come into contact whenever the sills are popped into place? Or do these rear ones not illuminate?
  5. ockevin
    ockevin Active Member
    493
    148
    Orange County
    This video is only for the rears. The front are the only lit version.
  6. GoldPianoGarden
    841
    74
    98
    Brunswick, GA
    ok, cool. I have aftermarket ones that light in the front and back, and I was dreading when the time came to wire them up....so I was excited that I finally had a how-to video that would show me!
  7. khoakhoa
    96
    28
    san diego
    for visuals only, no audio, video 2x speed
  8. rickelchilango
    rickelchilango Junior Member
    32
    Got mine this past weekend and was able to install them in no time.. I'd say an average of 5 minutes per side (not counting the rears, since those are no more than 1 minute per side).. I'm very happy with the way it came out, absolutely worth it, in my opinion..
  9. khoakhoa
    96
    28
    san diego
    I agree, I like them, wish it was stocked like this and stock led on the rears, I did not like the aftermarket versions with the rear led so just went with the Toyota Genuine part. It looks fine I just didn't prefer it.
    It will make you want to upgrade your OEM puddle, interior Map / Dome Lights. Since it will become more apparent how dim / yellow they are. I am leaning towards a Neutral White or Bright White SMD approach. I have not found ones that I would like to buy yet and at the right price. As expensive as some of the kits are I would rather build one with the higher SMD LED technology that is out right now.
  10. khoakhoa
    96
    28
    san diego
    Finally got Fronts uploaded =)
    Fixed Audio / 1x Speed
    Processing now
  11. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I couldn't agree more. My car lights up like a baseball stadium.:rockon:
    Two of these in my dome light, smaller versions for the map, vanity, puddle, and trunk lights.
  12. khoakhoa
    96
    28
    san diego
    I just bought exLEDusa set, neutral white and full set though pricier 99.99 and dim adjustable
  13. khoakhoa
    96
    28
    san diego
    Just heads up for PIP Plug in owners, there will be a exLED set coming out for the maplights
  14. tarheelsfan873
    tarheelsfan873 Junior Member
    Illinois
    GoldPianoGarden, are those the ones from Tommy Kaira? I believe there are two different versions. If those are the ones you have could you upload pictures. I have a Red Prius and think that the Toyoto OEM Sill Plates would look bad as they have a blue light. I know the TK versions have red light that shine through the RR in the symbol. Or does anybody know if you can change the color of the bulb in the Toyota OEM Door sills (for me I would change out the blue and put in red).
  15. tarheelsfan873
    Illinois
    I cannot find the answer to this question in all of PriusChat forums. Anybody? I have a red prius and have been wanting to purchase/install these but not with the blue color bulb. I would probably switch out to red or white.
  16. khoakhoa
    96
    28
    san diego
    I have not checked, I will uninstall it to see if I can remove the sill with out damaging it, wish I had those Vinyl panel remover tools for that =)
    tarheelsfan873 likes this.
  17. khoakhoa
    96
    28
    san diego
    Sorry for delay, rediculously busy and finally got the removable door panel tools,
    Hopefully this helps, for what its worth...
    lensovet likes this.
  18. khoakhoa
    96
    28
    san diego
    ExLED has them out, I just got the map lights and they fit great, just happened to be the wrong color, they also have the diffusion film for the light to help with dispersion.
  19. GoldPianoGarden
    841
    74
    98
    Brunswick, GA
    No, they aren't the Tommy Kaira ones. They are from the same seller on eBay that links have been posted about previously (seller is 'abravepig', or something like that). I contacted them right off the bat, because I liked some of their designs I saw on some of their other cars, and they "customized" 4 of them for me so they say 'LEXUS'.....to go along with my Lexus theme on the car. I'm thinking they also did the white LED for me....but I've slept since then. I was originally gonna add some of the blue Hybrid-esque accents to the car here and there, so I mighta ended up going with the blue lights after all. But then later, I decided against any blue stuff after I saw how well I liked just the black and white theme. I have yet to hook them up, so I don't know..and can't remember! lol
    Also, I just got the notice in my email this morning that u messaged me DAYS ago. Sorry!
  20. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
